M3kanic
Not hard at all. I believe its 10 bolts and a few plastic clips. Pull out the sides and slide it off.
GranPrix
How hard is it to remove the bumper?
Super easy. You have 8 10mm bolts to remove and 4 screws by the wheel wells and it's a matter of jiggling it straight out after you clear the tabs by the wheel well.
Still nothing like the good 'ol days where you pull up and remove two L-shaped pins and the headlight assembly came right out. Why couldn't they keep that design?!
Phoenix2k9
