Weird LED bulb issue.
Rangel
Great State of Texas
I recently converted my exterior lights( except heads and fogs) to LED. I used the Novita LM487 flasher module to take care of the hyperflash. My problem is with the corner markers in the from( #194). The first set I installed worked fine until the parking and or headlights were on then I had no blinkers and the blinker indicators on the dash were half illuminated. I removed them and all worked fine. I ordered different bulbs. And they work with the parking and headlights, but the dash blinker indicators are still illuminated. Any ideas on what is causing this?
Sent from my SAMSUNG-SM-G891A using Tapatalk
95escahoe
That’s odd, I run the same flasher with LED’s with no issues
Wylie_Tahoe
front and side markers are often wired in series. This works with incandescent bulb, but not LEDs. Look at a schematic for those suspect bulbs. If in series, you will need to re-wire to parallel.
Rangel
Rangel
Which LED's?
Tried these first.
iBrightstar 9-30V Extremely Bright 3030 Chipset 168 175 194 2825 W5W T10 Wedge LED Bulbs for Side Marker Light,Amber Yellow https://www.amazon.com/dp/B072BYX73R/ref=cm_sw_r_cp_apa_WL.6Bb46TGM8K
I tried these the second go round.
JDM ASTAR Extremely Bright Canbus Error Free 3014 Chipsets 194 168 2825 W5W T10 LED Bulbs, Amber Yellow https://www.amazon.com/dp/B018GYMOZ0/ref=cm_sw_r_cp_apa_lK.6BbYFNY9Y8
HiHoeSilver
Away!
Chicago
I wonder if the canbus is screwing it up? The first one doesn't say it, but it does say non polarity design which I think usually means it's canbus. I haven't done my markers yet.
