[Update 04/07] 2006 Yukon Denali Winter Beater [SOLD]
Galandorian
Galandorian
Albany, New York
I meant how do they compare to the factory lights
the housings, or the bulbs?
LED bulbs I feel are a lot brighter, but don't have as far of a range, if that makes sense
for the housing, I feel like they are pretty much exactly the same in terms of light output
hopefully that helps
Really clean looking Denali! Keep up the good work.
Regards from Sweden
Thank you <3
Always super cool to see GM lovers in other countries
from what I hear, these vehicles are kinda rare over seas!
Thank you <3
And expensive.
Galandorian
Galandorian
Albany, New York
Yesterday I got my shipment of deadener in
since I usually spend like $500/vehicle (Second Skin Damplifier, B-Stock) and only keep them for 2 months... I went the "cheap" route this time.
180 square feet of Amazon Noico 80mil for $319.95
unfortunately, it left some pretty sizable holes in the headliner, so I have to go check the junkyard and see if I can find some headliner with a Sunroof, without any dvd players
my box designs should be done this weekend, and then I can pay my guy to start working on A-Pillars, boxes, and front doors.
thinking 3 10" mids per front door currently
6 12" subs
about 10kw, and 100ah of lithium with a 390a alt
Galandorian
Galandorian
Albany, New York
haven't had much time to put into the vehicle with all the hours I've been spending at work lately
that being said, I dropped off my panels and money to get my stuff built
so here's the design for the 6 12s:
went with 3 Eminence Delta 10A's and 2 Selenium ST200 tweeters per door
about to go deaden some more doors and try to get my head unit and backup camera installed
Galandorian
Galandorian
Albany, New York
spent the last few days working on head unit and wiring stuff, ugh.
GM did not make these vehicles with enough space back there for all the wires I try to jam in there
had to cut out the support again to be able to fit things
surprisingly put back together nicely
no sound right now though, because this vehicle has an OEM amp that I have to bypass still, but I just wanted to get the vehicle drivable again so I can drop it off and have my rims swapped hopefully this week
head unit, Axxess ASWC-1 (to retain steering wheel controls) 3 RCAS, backup camera cables, oem cables, etc.
I also had to rip out that metal support, which was sharp as hell! Just to fit my dd in.
kylesimmons
