CCM before and after
jtub910
Wilmington, NC
Thanks to this forum I decided to pull the trigger on the CCM 2.5 level for my 2010 Tahoe. If it wasn’t for searching these forums I never would have heard of CCM. They were easy to deal with and the level kit was 20% off on their site. Here is a before and after picture. It surely makes a difference and it still drives the same.
When I purchase the truck last week it came with 275/65/18 Goodyear Wrangler Fortitude with great tread. What a first world problem to have... when these wear or I can’t take it any more I will move to 275/70/18 BFG AT KO2s. That will jump it up from 32 to a 33. With the life and size of Goodyear’s now I’d be dumb to waste them.
I’d love to hear your thoughts. If you’re on the edge I’d say grab this kit. It gives you extra beef without throwing anything out of wack.
Fir_Na_Tine
Looks good. And I agree stick with your current tires until they are up for replacement. I did the CCM level and also upgraded my shocks to Bilstein 5100's which I can't recommend enough as the ride is now better than stock. For tires I went from a 265/70R17 to a 285/70R17 Basically a 33 with no rubbing. But I will get Fuel wheels with a -12 offset so might have some rubbing there.
BeauDuke45
What’s you gas mileage after adding the kit?
Bizzo
Looks good! Did you install the rear spacer as well? I’m on the fence between this and the BDS kit. The BDS kit claims it doesn’t max out the upper ball joint by using a preload spacer on the strut. Did this kit max your upper ball joint out?
AT4Hunter
