Treating/blasting frame rails
no cigar
Hey guys. I'm curious how any of ya'll might have gone about treating or blasting the frame of the truck for rust and corrosion..... with the body on or only slightly detached?
At a minimum I'd want to do the frame from the firewall forward. I'm starting to look into a restoration and I really wouldn't feel right not addressing flash rust and such -- possible corrosion due to having the truck on the Texas coast for 2-3 years.
camaroz2887
Nj
Hi no cigar
I can’t really speak about how to do it for your vehicle as I really have no firsthand knowledge.
However I can say I’ve had good luck with chassis saver from http://www.magnetpaints.com/underbody.asp. Some people prefer por-15, and some would say neither but it’s worth lookin into atleast.
Good luck
TARDIS
Jersey Shore
https://www.amazon.com/Corroseal-82...=UTF8&qid=1531331013&sr=1-1&keywords=coraseal
This is Corroseal. It does a great job and it is EASY.
I'll post some pics soon. I'm doing this to my Yukon.
Scrub off the surface rust, just the powder and flakes. Then brush or spray coat the surface. The chemicals turns everything white. It's fine to apply thick coats. A few hours later, the rust conversion turns everything a matte black that looks very OEM.
Here’s what I started with. I’ll post pics of the process.
fastpat
Upcountry South Carolina
Whatever you do, don't actually use sand to clean the surface. It cut's too much of the surface. Use glass beads, walnut hulls, or baking soda to clean the surface.
I'd use a chemical coating first, as recommended above or something like POR-15. I'm a big enthusiast of high zinc containing coatings on top of the other chemical treatments.
Let's us know what you chose, please.
Goodlife_chevy
