LT vs LTZ same as SLT vs Denali?
AngelXL
Current owner of an XL SLT.
I'm searching for 2016 Yukon XL SLT or the Suburban LT but recently I came across a sale on the LTZ. Price is way below of the other 2.
Is a right move? I'm don't need a bigger engine. What's the difference?
Kpwweb
Cooled seats, daytime leds, magnetic ride control, 20" wheel size minimum, and, as stated, different trim.
Chevrolets all use the 5.3 with the 6L80e six-speed trans.
WillCO
Castle Rock, Colorado
The main differences between Tahoes and Yukons are in names and packaging choices on options. Yukons appear a little more expensive but include more equipment as standard that is optional on a Tahoe. Some of the color and equipment names are different, but the underlying kit is mostly the same.
You can come very close to outfitting a Tahoe LT such that it has the same equipment as a Yukon SLT, and pricing will be very close when you do.
If you opt for a Tahoe LTZ, it will have HID headlamps and a magnetic-damping suspension, neither of which you can get on any other Tahoe nor any Yukon except a Denali.
If you opt for a Denali, you get a larger engine and 8-speed transmission unavailable on any Tahoe, including the LTZ.
Clear as mud.
Weber Dude
THis is how I see it from base to top of the line - SLE, LT, SLT, LTZ, Denali, Caddy. Then it comes down to body style.
cardude2000
If you opt for a Tahoe LTZ, it will have HID headlamps and a magnetic-damping suspension, neither of which you can get on any Yukon, even a Denali.
Clear as mud.
Huh?
All denalis come with magna ride AND HID headlights... (As well as the 6.2 and 8spd)
Sent from my DynaTac8000 using Tapatalk
DLM_GT
