My factory Sub blew today...
BlueTahoe2001
Charlotte, NC
Well, My factory subs life has come to an end...
Time for a new setup! Excuse to blow some more money! Think I might go with a POLK Sub back in the factory location and a Kicker Amp...
Would it effect the amp if I build a metal frame for the amp to mount to? As in would it ground it so it would not work?
kses123
kses123
Raleigh, NC
What I did was I mounted the amp right to the sub box. On the right hand side (towards the wheel arch) It fit perfectly under the big plastic panel. No trimming or anything.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I would prefer NOT to mount the amp directly to metal... it does form a ground loop.
Shouldn;t be that hard though to isolate it electrically, even if that means a masonite board mounted to the rack and the amp mounted to the masonite. assuming you have a metal amprack,
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
Yeah that sounds better then what I was going to do. Then I will build a frame to bolt to the seat frame and then bolt or screw some 3/4 MDF down to it and then mount my amp.
Eagle
EL PASO, TX
the ghetto fabulous (but very effective) way to do it is 1/4" ply under the carpet with t nut inserts. Just make a small incision and bolt the amp thru the carpet.
this is how they installed the PS2 that used to be under the seat in the Hoe b4 I bought it.
Woned2004
