Project---------------Tahoe
M Hankel
M Hankel
Vancouver, WA
Looks good.
also I embeded the vid for you
Thanks. I added the link back also because my android devices (Kitkat or Jellybean OS's ) can't view embedded video on this site. I'm assuming others can't either?
Mike
---------- Post added at 11:02 AM ---------- Previous post was at 11:00 AM ----------
Good looking project you got here, Can't wait to see the end results
Thanks man. I've followed your build and It's sick. Not looking to take Mine that far but it should be a fun daily driver. :)
Mike
bottomline2000
Dallas, TX
I have kit kat and can see embedded video. Project coming along nicely. Keep us posted on using the pcm for fan control.
Sent from my SAMSUNG-SM-G900A using Tapatalk
M Hankel
M Hankel
Vancouver, WA
I see you're using Tapatalk, that might have something to do with it. I don't use that with my phone or tablet. I like the layout of the desktop versions better. This is the only sight I can't see embedded vids on though.
Yeah i'll post up my results from the efan harness debacle.... I hate the way it triggers the high speed when the defrost is turned on. Seems like a Band-Aid fix to me.
Mike
_mostcommon
really nice build up so far, that shifter makes me want to start a t56 swap and get rid of this old 4l60e. Oh yeah and your tahoe looks pretty clean with those plasti-dipped wheels.
dantheman
Houston
this is an interesting build. your shifter mechanism gave me quite a giggle. i was honestly surprised at the video cause it seems to work fairly well. though i bet the shift effort isnt very easy.
also i have that clutch in my GTO and i LOVE it. drives like a stock clutch and takes a good amount of abuse. its been in there for almost a year and zero issues.
M Hankel
M Hankel
Vancouver, WA
Thanks man. The plasti-dipped wheels have really grown on me. Its amazing the difference it makes in the way changes the vehicle "persona".
The shifter is actually quite effortless, I could shift it with a finger. I removed the centering springs from the two bottom shifters just because of that reason. I figured it would be hard to shift having to overcome all those springs lol....
I'm really happy to hear that about the clutch. That was one of the things I was sweating with this swap because this is my daily driver. I don't want to be replacing clutches every year with it being so heavy. I think the 5.13 gears will help alleviate the initial strain of getting moving off the line.
That said, I'm seriously thinking about taking a couple days off around Thanksgiving and doing the trans swap then. I still need to complete the mods to the pedal assembly with Tilton master cylinder and either order up a custom hyd line or have one made locally. Hoping to get some of that handled this weekend and will be the deciding factor on whether the swap happens on over Thanksgiving.
Mike
dantheman
Houston
granted its not tahoe, my GTO weighs around 4000 with me in it and there is no strain driving it off the line with the stock 346 gears.
i made a video of my driving around town with the clutch for a few guys on the GTO forum and since Steve at Monster is a good buddy of mine he wanted some feedback out there.
warning the video is REALLY boring. its just me driving around town in houston.
https://www.youtube.com/watch?v=cVj6PgdHAi4
M Hankel
M Hankel
Vancouver, WA
Yeah Steve at Monster Clutch is great. I had a Monster Level 3 in my Camaro for a few years. It basically was just a drag car and when the original friction disk wore out, I asked him how much a replacement disk was, he just sent me a new one free of charge. The pressure plate still looked new and the flywheel got a fresh surface on it. So yeah, going with Monster again for this project was a no brainer to me. You just don't find customer service like that anymore and I've read numerous horror stories about Spec clutches...
Mike
M Hankel
M Hankel
Vancouver, WA
A little bit of progress from this weekend before I tweaked my damn back getting up under the dash of this thing. It's super cramped under there.
Still getting the clutch pedal assembly worked out but figured I'd clear out the space where it mounts to on the firewall. I'm fabbing up a custom bracket for the clutch since the stock ones don't seem to be very strong.
The two holes on the right is the only thing holding the clutch pedal assembly to the firewall. Then, right where that red power cable goes through the firewall is exactly where the hole needs to be enlarged for the master cylinder. My friend installed my stereo amp and decided that was a good place for the power cable.... normally this would be true.... now I need to relocate the power cable. :(
Had to cut back some of the stock plastic covering and sound deadening material.
The stock brake pedal is way too wide and needs to be replaced with a smaller one from a manual trans pickup, or the alternative is cut down the stock pedal and install a new smaller pad. I opted for the latter version... :)
Taking measurements from the clutch pedal.
Transferring the measurements from to the brake pedal with the stock pad removed.
Cut the extra material off the brake pedal and deburred the edges.
Installed new smaller pad and voila... done.
Mike
M Hankel
M Hankel
Vancouver, WA
Just a little update.
Trans swap has not happened yet. I messed up my back so I've been waiting for that to heal up.
In the mean time, that gave me a shit load of time to hunt around the stupid internet looking at interesting things and putting evil thoughts in my head.... So, I purchased one of the cheap Cadillac LSA blowers found all over eBay. Long story short, the engine just might become supercharged! If this happens, I'll have to lower the compression down, which will probably require a different piston. This is a "budget build" so to speak, so as luck would have it, I found some used L92 pistons for cheap that will work with the Gen IV connecting rods I already have. Those pistons should reduce the compression to 9.6 with a LS3/L92 cylinder head. A bit more than an LSA engine, but def doable for a mild SC engine. If you're unfamiliar with the LSA engine, they're making crazy amounts of power with relatively mild mods, 550rwhp is considered pretty tame with these....
What I've collected or purchased already.
Stock L92 Pistons
LSA Supercharger
LSA Stock Upper Lid
LSA stock heat exchanger
LSA Stock heat exchanger water pump
LSA Stock Balancer/Lower Pulley
Still need (short list):
LSA Front accessory drive
LSA Injectors
New SC friendly camshaft
Misc Sensors
LS3/LSA/L92 heads
Re-machine block for L92 pistons
Re-balance rotating assembly
Stupid internet....... that is all.... :)
Mike
_mostcommon
********, this build is going to be vicious. Good luck on your back recovery my man.
Mikeyjm1
I'm an Avalanche owner and just joined this forum to follow this build. Keep up the awesome work.
Mike :waytogo:
M Hankel
M Hankel
Vancouver, WA
So this happened..... spider gears from the Yukon Duragrip limited slip I installed a few months ago.
******* Awesome! Read a bunch of good reviews about this unit. A couple lately have been doing this with the spiders. Product of outsourcing overseas?
Mike
Mikeyjm1
Yeah, somehow, my G80 is still alive, but I already know it'll get replaced with a Detroit Trutrac. It's just the one unit that holds up for everyone.
M Hankel
M Hankel
Vancouver, WA
Welcome btw....
Yeah it seems like the early versions of the Duragrip help up great, even a few making some pretty good power. Lately I've seen a few people having issues with the spider gears. Just wondering if Yukon recently started outsourcing the spider gears overseas. ? I'll put this one back together and limp it along until summer hopefully. But, I'm already looking at other alternatives for the rearend. If I end up going with the supercharger, the 10 bolt will be living on borrowed time IMO, especially with a manual trans. The Hummer H2 uses the 14 bolt semi-floating rearend with disk brakes and nearly a direct bolt-in to a Tahoe/Suburban etc... It has a much larger 9.5" ring gear and is a pretty stout piece. The NNBS Escalades also have one but they are harder to find and more expensive.
---------- Post added at 12:20 PM ---------- Previous post was at 12:19 PM ----------
Thanks man. The back is getting better. Just not a young buck anymore so everything seems to take much longer to heal up haha...
tgui
Sucks man!
I'm saving pennies for a Detroit TrueTrac like the poster up a few ^^
Woned2004
