CAResearch
- Joined
- Nov 10, 2010
- Posts
- 77
- Reaction score
- 0
Hey all I upgraded my front rotors/calipers/brackets and pads with 07+ size parts (rotors and pads)--saw a thread where this was done for increased stopping power, yet I seem to be having some weird ABS issues.
I have tried numerous times to bleed the system (as I had to remove the brake lines of course) on the two front calipers. I bled : (rear-pass) to (front-driver) to (rear-driver) to (front-pass), bleed till no bubbles. The front driver caliper seems to not be functioning correctly as very little fluid is coming out. and I keep getting a service brake system error and absolutely no brake resistance at all. The pedal is very soft. I pretty much only have rear brake stopping power, and of course the parking brake
I can also hear slight mechanical wear, when slowly driving around the block. Also the new rotors have a thin wear line only on the top outer rim of the rotors. Almost as if only the top 1/16' of the pad is contacting the rotor. This is on both sides. I can take pictures and post them if that helps
I removed stock 04 rotors/brackets/rotors and pads, that were badly worn, and I have 20" rims that came with the car when I bought a few years back. Should I scrap the larger rotors/brackets/calipers and pads, and just go back to the 04 size? and would it best to wait for a pressure bleeder like a motive or just have it towed to a local brake shop to have the system bled?
thanks for any help, I am stumped
