98 Yukon. New Column, Wont Start?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if it was from a 96 you have a serious problem. it is blinking becuase there is a problem in the passlock system if the passlock parts in the '98 were not moved over to the '96 column(never even seen that tried by the way) the system will assume an illegal vehicle start is taking place. the passlock lock cylinder will trigger the passslock sensor and if it sees a proper trigger from the lock cylinder it will pass the info the to the passlock computer and that will trigger the pcm to enable the fuel pump to run. if one part is missing it may fail-safe allow that will let in run with the light on the whole time or just fail and lock out the fuel pump. you can try the relearn procedure but all the parts must be in place. you can also visit a company with a proper tuning program to disable the system. dealer can do it to i think.
McFizzl
Broke as a Joke.
Fayetteville, AR
disable the passlock. had it in my previous car and it always failed to start so i disabled the crap. Your security light will be on permanently but you can always pull the bulb
McFizzl
Broke as a Joke.
Fayetteville, AR
You can do it that way yes. IF! the wires are there. you solder a resistor inline with the wires. You can also disable the whole passlock system and take it out of the vehicle.(Comes in handy when going aftermarket security).
Found this for Passlock 2. Idk if thats what you have
http://coloradofans.com/forums/67-t...w-permanently-disable-passlock-ii-system.html
And this is Passlock 1
http://old.kingbain.com/how-to/how-to-permanently-disable-gm-passlock-system.html
Good luck. I did it differently tho. I just started ripping crap out in a rage. I dont recommend it.
M
mattcon40
How could I figure out witch pass lock it is? I know the key has no chip or resistor in it
SunlitComet
OBS Jedi-Do Good
take a pic of your key to post here to be sure but if they did not transfer those parts then yeah the truck is dead until bypassed. further more you can not remove the system after you bypass it. the module co-mingles with evo system for steering.
M
mattcon40
Thanks. I will get a picture of the key today. It's a regular key with the vynal gm logo. I also have a straight metal copy they both do the same thing. No resistor on the key it self. I'm wondering if I can bypass this even tho it's an older column because I don't get the steady security light. Maybe I wil have to swap the passlock to a newer one or end up swapping the column all together... Man I win they didn't throw out the old column lol
SunlitComet
OBS Jedi-Do Good
sounds like the normal passlock 2 to me. there are bypass kits out there. the problem is tho they are usually wired to the passlock controller AND the steering column components.
kylesimmons
