Leveled Yukon's
GAW10
alright just wanted to say that this is a great forum...i started out on the other yukon and tahoe forum and was very disappointed until i found this site!
now i am looking for pictures of leveled yukons either front only or the front and rear truxxx kit. also my yukon is a denali so i was also wondering what yalls experience has been as far as changes in handling and ride comfort with the AWD system. i have found a few various pictures but they have all been 4" lift which is a little much for what i need so any input would be greatly appreciated.
tast101
Colton, CA
welcome aboard. Everyone will chime in and start post pics by tomorrow.
Modded
That Guy
Welcome along!!
Dude are you relly tryin to lift a Denali??
I say you level it by briging the front up 2-3" up front with the Pedders coil s;ring kit or any other level company, alot are over at www.4wheelonline.com
Remember actual coils ride better than spacers, so thats why I suggest Pedders.
Mr. B
Rockford, IL
If you use spacers, you retain the factory ride. Why would coils ride better than spacers?
G
GAW10
alright just wanted to post the best pic of a front leveled yukon i have found...
also what tires are people running on leveled yukons? i currently have 305/50R20 on stock ride height i was thinking about 325/60R20...
also i wanted to throw another quick question in here. for the people that are buying aftermarket L.E.D. taillights like these
http://cgi.ebay.com/ebaymotors/2008...d60&_trksid=p4506.c0.m245&_trkparms=65:2|39:1
have you had any problems with them that i should know about or is there a better place to buy them that is just as cheap?
Modded
That Guy
No coils don't retain the factory ride becuase the coils have to be compressed more than normal to make them fit. Ihave plenty of friends with spacers and they acknowedge the ride got a bit rougher, the platics spacers do ride better than the aluminum ones.
Actual coils are better and around the same price so you might as well.....
---------- Post added at 01:49 PM ---------- Previous post was at 01:47 PM ----------
Also I can't help you with leveled Yukons as barely anyone from 07-Up has them on here! I can tell you after leveling you will clear 33" tires, if you want t clear 35" or 37" tires you need an actual lift kit from Rancho, Bulletproof or maybe Cognito )all pretty expensive).
I do know about LED tails as I have the same ones you posted just in theBermuda Black color, they are tite and you found a better price than I did on them!
G
GAW10
thanks for the help Nnaboy...good info on the taillights, and i dont want to run anything bigger than a 33" but i just wanted to make it sit flatter and have a tire that will fill up the massive wheel well a little better.
InTruckDesign
SW CT,
I do not have a Yukon, but on my Hoe I have the CCM 2.5" spacer, and have a 1" coil spacer in the back...clears 305/55-20's with a little trimming..fills the wheelwells nicely and has not changed the ride...if anything it got a tad better as the sidewall is taller now.
05Yukon
Houston
There is a denali xl over by me that I believe was leveled I can try to get pics for you if you want.
G
GAW10
05 yukon don't go to the trouble...thanks for the link MR. B that is actually where i found that one good picture... i think ive decided to go with a front only level when my pirelli STR's finally wear out and some bigger rubber thanks for all the help
Mr. B
Rockford, IL
I've decided the same thing. Unfortunatly, my tires are pretty fresh. The look I'm going for is exactly like that picture you posted. For the price, I'm thinking about going with that Rancho kit on the bottom from the link I posted. By the time I need new tires, struts will be a good idea too.
Kerrville15
Kerrville, TX
Here's a couple of pictures of my wife's 2007 Yukon with a 2.5" CCM leveling kit up front with a 1" spacer in the rear. The tires are 285/65 R18 on 18x9 Rockstars. It rides just as good as it did stock & I would recommend this kit to anyone.
G
GAW10
looks great Kerrville that is exactly what i was looking for! does pirelli have strange sizes because my 305/50R20 look average on my yukon and do not come close to filling the wheel wells....am i missing something???
nc6600
ps trucks in drive
Cary/Apex NC
Damn that is a nice Yukon.
FadedSS
San Jose, CA
do you have any pics of your setup? i would love to check out the wheels/tires/level kit
Zed 71
Pacific NW
GAW10. +1 on CCM.
Tony, yes you can level out an LTZ with the air shock. You can even add a spacer back there, but depending on the spacer size the air shock rod will need to be adjusted. There is a thread in the suspension section discussing this.
JohanZ
