mcgaughys 2/3 drop
ok well i tried to post this on two different forums and on this one in the suspension section already, but nobody seems to be willing to shed light on this for me. so here goes. tomorrow i will be taking delivery of my mcgaughys 2/3 drop part number 30008. i paid $492 shipped. after ordering it i discovered all these issues with traction control and ABS lights on the dash after installing the kit. it seems to be mostly people with the 2007 lt and mine is a 2010 not sure if it matters. now im worried and wondering if i should even install it. some say its only when turning sharp or slow parking lot manuvers. either way i dont want to create an issue thats not there now . so what causes it? someone on here has to have this drop on there 07+ tahoe. can those guys please tune in. im thinking about installing just the rear then driving it, then the next day do the front just so i can isolate the problem being front or rear. i hear its something about the spindles, some say its pulling too much tension on the abs wires for the rear, some say that it is fixed with alignment, lastly i heard that since it rides lower the truck thinks its rolling over easily. either way i never found a direct answer, fix, or explination. i went with mecaguagys because they have basically the exact spindle gm uses now, and i figured it is the best one but i guess i found out that i should have talked to a guy name tony on here. lol too late now!
JochenWoern
Sacramento, CA
It is NEVER too late to contact TONY (NORCALSS) @ 415-519-2432
CALL or TEXT MESSAGE him ANY TIME, he WILL get back to you and will give you all the input you need.
KMeloney
Jerry -- I think that a lot of people here have gone with Belltech, and maybe in part due to some of the issues you mentioned seeing with the McGs kit.
"Modded" here has the McG spindles, and he's really low, and I don't think he currently has issues. I think he DID have some issues, but he said there is a TSB for the lights that may come on after lowering, and I think that the fix includes a flash from the dealership. PM Modded, and he can probably shed some more light on this.
Also, if you ordered the kit, but haven't installed it, then why can't you return it?
JochenWoern
Sacramento, CA
^ +1 on returning the NOT installed Kit!
bauer4567
Allentown, PA
Return it and talk to Tony. The guy is is a wealth of knowledge, a gentleman, and good businessman...
THE YETI
Director of Operations
South FL
had our 2/3 McGaughys drop for about 3yrs in our ride now. 2008 LTZ. No lights, no issues, nothing at all. Rides great, drives great.
GalaxyBlackEsky
BlackedoutLT3
MD
I have the 2/3 kit as well. I have just the traction control light that comes on when doing sharp turns but that is it. Flashes on for a sec and goes away. Half the time I don't even see it because I am looking at the road when turning. But it doesn't hurt the vehicle in any way.
cmblack13
Built Motor Coming! :)
Farmers Branch, Texas
I def like your setup Blackedoutlt3!!! rims are a great choice, drop, brakes!! very clean and job well done. Dont know if I am ready to drop the tahoe down yet though since I will be hauling my track car with it.
baddohtentahoe
so i decided i was going to stick with the mcgaughys. today i installed the drop springs in the rear only. i drove it and everything went well its a bit bouncy but not too bad, no lights or anything, tomorrow im going to install the front drop knuckles at school where i have a lift and heat and an alignment rack, this way i can do the alignment right away. i also called mcgaughys and spoke to a gentleman that said the people that do have issues with trac and ABS lights come on have not had a proper alignment yet. he said that CASTER CAMBER AND TOE must be adjusted not just camber and toe. without having it alined correctly he said the truck thinks it wants to flip over so it flashes those lights. otherwise truck looks awesome, i had to fight with the left side spring for it to line up with the frame pad. i did use the factory isolators. and i also found out that the springs CAN be installed upside down. i just put the part that sits completely flat on the axle and the side that tips a little on the frame. looks right to me. bud i did notice the brake line looks like its rubbing on the blue part of the shock. im not worried because that part of the shock doesnt move.
GalaxyBlackEsky
BlackedoutLT3
MD
Ahh you will be fine. I have trailered my show car with this and also my bro's twin turbo mustang a few times with it lowered on the 26's. You will be find just need to add the rear airbags for inside the coils and it will be fine.
Woned2004
