Supercharger vids finally
Sam Hamm
I'm using Infinity Kappas. You cant just trim the door panel. You have to build a new baffle on the door panel to ount the speakers to. It's a tight fit depthwise, so you can't use anything with a large mounting depth.
yea i seen where you had used foam or something to sit the speakers up towards the screening a little. i have a full ppi system and i was going to try and run two 6.5s in there but they are just way to big and the second one would def cause some problems so i was just going to ask how you did it.
my dad owns a shop and he was telling me its not possible and i showed him yours and we really just wanted to know what you used.
JKmotorsports
JKmotorsports
Austin, TX
I formed a piece of 1/8" ABS as the baffle, but you have to reinforce it with braces to prevent them from flexing and loosing mid bass response.
Sam Hamm
ight man preciate it. let me know when you want to swap for the weekend. ill come and meet you haha
Nickleahy23
Portage/Menomonie, WI
so badass man..makes me want to save up and get one on the 6.0...
i got a question..what are you runnin for a tranny? what upgrades? im just curious because im scared to run my 60e on my 6.0
JKmotorsports
JKmotorsports
Austin, TX
Right now just a stock 4l60e with vette servo. The tranny is the next upgrade though. Fully built 650hp capable 4l60e hopefully by next month.
Nickleahy23
how much power are you running right now? alot more then ill have right away im guessing.. if you have lasted for a little while with a charger, ill be fine with the stock 6.0 for a while with a shift kit and servo and a cooler..
JKmotorsports
JKmotorsports
Austin, TX
Haven't dyno'ed yet. Mustang Dyno charts on a 2000 5.3L show about 131hp/127tq gain at the wheels with the stock pulley (~5 psi) on the Magna tune. I'm running a smaller pulley with about 9.5-10 psi, intake, exhaust, and BB tune.
You should be fine for a little while with your stock 6.0 and trans.
Donnie Yukonie
Yates Caretaker
that thing sounds soooooooooooooooooooooo nasty i think i messed up my pants 5 stars!!!!!
Woned2004
