anyone do E-fans on a obs??
Status
Not open for further replies.
AtomicHoe094
Atomichoe094
cleveland, OH
16 pages of crap. lol hahah
Naa i dont have anything for sale. Bought my flex kit for 200 or 250 bucks shipped. hasnt let me down.
sparg93
Expedition Tahoe
NJ
wow - 17pages.
Someone should do a CONSOLIDATED writeup to be stickied that discusses all the approaches, costs and do's/don'ts. Hmm...who could do such a thing...:drunk:
What I get a kick out of, do we ever really discuss the REAL BENEFITS from the efan mod??? Honestly, I have a 6700lb truck (4dr 4x4), is removing my clutch driven fan REALLY benefiting me?? I know I now have lots of potential "points of failure" but I honestly didn't see any benefits after driving with my efan.
retorq
Kingman AZ
17 now ... Jeeze when I did mine I wired it up the way the instructions that came with the thing said too. No search, reading, posting or anything like that involved.
gpracer1
Phoenix
wow - 17pages.
Here is a quick summary of the pros and cons of stock vs efans.
Stock
Pros....everything is oem and easy to get parts.
The fan is always kinda on when engine is running, so your trans cooler at least has some air going through at all times.
The fan clutch is totally automatic and you never have to mess with it unless it goes bad.
Cons.
In very high ambient temps it can be locked on hard. Even with full acceleration from idle to 5000rpms it will drag hp alot!
More wear and tear on the waterpump and belt.
It is loud when locked and engine is revd.
When cold engine temps (warm up) and AC on, clutch wont lock and suck good air till hot, causing possible AC problems in hot regions.
EFANS
Pros.
When you need it , it comes on stronger than oem at idle.
AC works better on cold engine and warm up.
Better AC performance at idle since way more air is flowing.
It is controllable set up by the user.
No engine drag (some on alt, but waaaay less than oem)
It shuts off while driving over a certain speed (PCM controlled) and usually also with radiator probe, but aftermarket AC trigger wont.
Not as loud as oem.
Much more room in the engine bay and safer for fingers.
In hot areas where the oem fan would be locked on alot, you will see mpg and power increase.
Cons
More expensive.
Need wiring, relays, controller or PCM control.
Fan motors can die.
When the engine is running and the fans are not on at a stoplight/idle, no air is going through the trans cooler.
Harder on the alternator and battery.
sparg93
Expedition Tahoe
NJ
Looks good GP!!
Locked and unlocked - I always thought they were in the locked position on our rigs?
Monstar_est87
City of Angeles
Hahaha... come on page 18... thanx again every1 for all the gr8 input... I did my homework before doing the mark8 conversion but came across problems I didn't expect... like my temp sensor controller burning out twice... not the relay or the fuse the controller... and now I'm trying to get sumthing that's going to work properly and reliably... this was sapose to be a cheap easy way to increase mpg and hp... but so far a P.I.T.A....
gpracer1
Phoenix
Looks good GP!!
The fan only locks up when it gets to the preset temp designed by the manufacturer.
When it sits overnight and you start up, it can take 15 seconds to 1 minute until the clutch can redistribute the silicone fluid back to the fluids normal disengaged operating condition.....according to the shop manual.
Wiki http://en.wikipedia.org/wiki/Fan_clutch
Detailed version of how the fluid actually works with the bimetalic "clockspring" thermostat
http://www.howstuffinmycarworks.com/Fan_clutch.html
sparg93
Expedition Tahoe
NJ
gp - great intel!! (i always thought it was fixed)
Holy crap if I knew this thing disengaged, I never would have done this mod!!! MPG savings my left one...
#178!!
AtomicHoe094
Atomichoe094
cleveland, OH
elec fans are still worth all the pros in my book. Sooo much cleaner looking, the noisy, faster heatups in the fall/winter time.. way worth it
179
Status
RobK
