No Tail lights!
InkSlinger
Akron, Ohio
I have brake lights, turn signals and 4 way flashers but no tail lights! I checked the fuses and put in new bulbs with no luck! Help, I drive to work at 4:30 am in the dark every day!!!
bowtiefreak
No Quarter
Near Philly
check the curcuit baord that the bulbs attach too, my guess is corrosion in there. A small piece of fine sand paper or a small stiff brisle brush might knock enough off to get them on again but the board will need to be replaced if that is the case. Its a common issue on these trucks
MOBmentality
Has a $25,000 Punch
Or the ultra budget redneck way is to solder in jumpers between the live end and the bulb end so it bypasses the circuit board
I
InkSlinger
Akron, Ohio
Fixed it! It was my wiring for my tow package under my rear bumper. There was a short causing it all! Thanks for the input everyone!!!
RobK
