Max tow?
munks06denali
colorado
What is the max anyone has towed with a 2006 6.0L denali? Thinkin bout makin a trip crosscountry to pick up a 31ft camper. Dry weight is 7695lbs with a 875lb hitchweight. I have the tow package and takin my baby would be alot more comfortable than takin my 96 powerstroke. anyinsights would be great. awesome site by the way.:rocking:
tybardy
everyone needs a Hoe
Gilbert Arizona
i pulled a 40' tow hauler in my girlfriends old 05 denali XL... performed just fine, however it was only right across town... im pretty sure the owners manual has the exact "recomended" tow capacity
JennaBear
Resident Ninja
San Diego, CA
We have towed a TA WS6 cross country 4 times with the Silverado (6.0L) I think you will be just fine, just watch your tranny temp, that is the weakest link.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
remember to use tow haul, and also remember on steep grades. those 3-2-1 gears are there for a reason.
munks06denali
munks06denali
colorado
Right, my main concern is goin through the rockies. Dont want to end up like all the u-hauls dead on the side of the road LOL. I have pulled me 21ft camper around and it pulls great. Bout 2400lb difference tho hehe
tybardy
Gilbert Arizona
im pretty sure at that weight you will be fine, luckily the denali has the tranny temp gauge... thats a nice feature... I dont know what to say about the rockies though.
IMO, i would say this though, if your going to make the whole trip in the denali but your spending the whole time worried and stressing over the tranny holding up, then it probably isnt worth the comfort of the denali...
Rollin Thunder
Va Beach Va
denali has a stronger tranny that a 5.3 liter, its not a 80 but its not a 60 either.
Rivieraracing
Get an upgraded tranny cooler, I did that to mine after I drove to Montana to buy my toyhauler, the tranny was alot warmer most of the drive back with the stock cooler and was noticably cooler ever since I got a bigger cooler!! Will pay for itself in no time the more you tow!!
Max
Mile High
Denver
the denali has a 5 pinion planetary but I wouldn't tow over 6k with these coil spring rear suvs, if you do please buy some inner springs helper bags or a bigger rear sway bar...coils out back are sketchy as hell whena trailer unloads on you...level 9 pucker factor for sure.
munks06denali
munks06denali
colorado
The fact that it has airbags in the rear makes no difference? plus an equalizerhitch?
Max
Mile High
Denver
are you asking a question here? I was recommending you buy some helper bags because it will drastically help sway control.
thumper_ehhhhh
Canada ehhhhh
It depends on what rearend gears you have. Your hitch weight is getting near the max for the hitch with weight distrubution and way over without. Those round tube hitches are crap and the hitch box has been known to fail. If you plan on towing I recomend a new hitch. Something with a 1000lb tounge weight with no weight distrubution. That way if somethin happens and you cant use your bars you can still get home. I picked up a reese hitch I had a problem towing last weekend with a failed part on the latch for the spring bars. Glad I didn't have the 600lb max tounge weight. I'm stilling at 800 lbs loaded.
jmildoc
Indianapolis,Area
i think that it will tow it just fine, like someone else said just use the tow/haul mode once your hooked up and take it easy through the mountains and keep your eye on the tranny temp.
99fever27
Just made a trip from Virginia to Washington state- 2900mi. My '04 5.3 3.73 awd tahoe did fine pulling a 18' 7,500lbs enclosed trailer with 1000lbs tongue weight. I used an equal-i-zer hitch and prodigy controller. I-80 thru the rockies was easy...but the winds in Wyoming is what I would be worried about. I used tow haul plus towed in 3rd the whole way. I averaged 11.2mpg on 20" wheels.
JohanZ
