Stumbled on this last night and i found it interesting enough to do some research. Seems it is fine to use if the engine is not using oil. What do you think?
What do 'I' 'think'? Reality is what's left after you die.Stumbled on this last night and i found it interesting enough to do some research. Seems it is fine to use if the engine is not using oil. What do you think?
Just curious: What makes you think you need to run ZDDP?If i needed a cat i would buy used or delete. I do know where i can get 2 used sets Monday if i needed + they are several Yukon's being parted out on marketplace.
Driven break in oil is about 2800ppm.
