AT4 XL - Largest Tires?
ProfeZZor X
High Country
Let's see if i can get these to fit...
RipEmUp
Fit report and question:
22 AT4 XL. I used the switch suspension links and added 295/70/18. They work great. A pain to get the old ones off (I even broke a sensor) but the new ones are easy and then much easier to get to to adjust after they are on.
No rubbing and the ride is great. A little bit stiffer but I like that. Feels more truck like.
One issue I have now is that all corners are set to 39 3/4 at the bottom of the fender well but the rear drivers side won’t go above 38 1/4. Even after several adjustments.
Also, the increased ground clearance level and the 4WD level are not available. You are just riding at that increased height all the time. Entry/Exit works fine. I’m assuming the aero mode does as well.
If anyone has any recommendations for the rear or adjust higher please let me know.
That looks really good. Thanks for sharing
Wheel offset?
Did you have to do any trimming or fender pull back kit?
I’m thinking of 295/60r20 (a touch shorter) stock wheels with the links and potentially the fender pullback kit. I reallly don’t want to trim the front fender and I’m worried about the UCA without a spacer.
Also, Did you figure out the link issue?
koomie98
