What brand name oil
B-train
This is going to get all opinions from all angles.......
Personally, I run a high quality 5w-30 full synthetic. I get mine from Reladyne - Duramax Full Synthetic. It has good quality base stocks, good quality additives, and rates well on the oil standard tests. Bought in bulk, I can get it for about $3.30 per quart.
wjburken
Eastern Iowa
Welcome to the forum from Iowa.
Might do a quick search here. I’m sure you’ll find more information and opinions than you ever thought you would need.
There are probably more threads here about oil preferences than anything else other than oil filters which is pretty much a tie. Those two are followed closely by threads about tire preferences.
That being said, people will certainly give your there opinion.
Marky Dissod
Newbie here. What brand oil are most using? Mine has 152K.
'What brand?' is negligently imprecise.
Have only used Group4 synthetic 0W30 or 5W30 or 5W40, with a strong preference for Valvoline, Pennzoil, Quaker State, STP, or Mobil1, since 1999.
Once Castrol stopped making their Euro Grün Öl, I swore off the rest of their schidt.
Recently fell for Valvoline's marketing hype about Restore & Protect 5W30.
Seriously considering cutting this stuff one quart at a time with the V R&P:
Welcome to the Forum from NH.
Pics of the truck, please.
I believe that you will be OK using just about any name brand oil, with the correct viscosity for your truck.
wilcfr
I've used Mobil1 in all my vehicles since it first came out and never had a problem. Switched to Royal Purple last change, didn't see any difference so going back to M1 this time. Honestly I think if you change your oil regularly and the truck isn't doing severe duty type work any good quality dino oil would work just fine. I just happen to like the extra protection you get from the syn oil. Mine doesn't always get changed on time.
waveryd
IL
Change interval is much more important than brand. Pick a brand and change it frequently.
mrkev
I'll be trying liquimoly for my next change. I can get it from FCPEuro so the oil has a lifetime gaurantee. I've done this with my other vehicles and was always able to ship back my old oil for store credit.
Congtoid
I am using valvoline R&P since my truck has 104k miles. I have tried Rotella T6 Multi vehicle 5w-30, regular pennzoil, Amsoil OE series. I couldn't really tell a difference between the 4 brands, but do some more research on which additives the brands use and which ones you need, and pick from there.
Well, I might as well regurgitate my preferences! LOL
I'd been using M1 since the 1980s, even proved those old commercials of them draining the engine of oil and they kept running. Sometime around 2010 M1 quit being a Group IV oil.
I noticed in my first two trucks that they would rattle a lot on start up with M1. After the 4th oil change I sent in an oil sample for analysis. Then switched the trucks over to ACDelco's full synthetic (5W30). No more rattle. After the 3rd or 4th oil change another sample was sent to Blackstone Labs to compare the two.
M1 had a lot more metal in the oil compared to ACDelco and the latter didn't cause the motor to rattle on start up, no more oil usage between changes and a slight improvement in mileage.
Several years later ran the same tests comparing ACDelco and Quaker State Full Synthetic and surmised them to be essentially the same performance wise. You be the judge, here are the oil analysis:
The Sierra's comparison is between ACDelco and Quaker State Full Synthetic:
On the Yukon's analysis below, the 2018 and 2019 oil samples are Mobil 1, ACDelco for the other three.
It is my opinion that what makes these oils better than M1 is their rating under ASTM D445 where their viscosity numbers are over 11.5 (100 degrees centigrade) or 66 and above (40 degrees centigrade).
Marky Dissod
SOME of Mobil 1's motor oils are Group4 synthetics, others are Group3.
Group3 is just hydrocracked de-paraffinated extra virgin fossil marrow with impurities minimized.
Castrol lobbied for this definition, by the way.
It's why I stopped using any / all Castrol after they stopped making their green oil, their last Group4 synthetic.
Group4 (what normal people consider synthetic) is motor oil entirely synthesized in a lab from synthetic ingredients.
JohanZ
