So not really a recall, just a Customer Satisfaction Program.
-I am the original owner. (I am nuts and OCD. I have the entire front end wrapped in PPF, handwash only, no eating in the truck, etc)Sorry to hear about your vehicle. It sounds like you heard the bottom end problem before it hard failed, unless for some reason the noise if from the High Pressure Fuel Pump. Could alse be the thrust bearing going on the crank?
A few quesitons:
Assume you are the original owner?
What weight oil did you run? 0W20, 5W30 or other?
You indicated you were fussy about fuel quality, explain this please? 89, 91, or 93 Octane and a specific brand?
What is the build month and date on the vehicle?
Since your vehicle is a 2023, do you know if your vehicle fell within the "Oversize Lifter Bore" group? Were you ever notified by GM about this issue?
Please update the thread on what the dealer finds as well.
Just trying to gather more context on these failures.
Thanks for the follow up.-I am the original owner. (I am nuts and OCD. I have the entire front end wrapped in PPF, handwash only, no eating in the truck, etc)
-Always 0W-20 per GM Spec
-93 Octane from BP is my preferred source of fuel, from a specific station that I trust. Will settle for Holiday 91 Octane when I have to, as they are all over MN.
-I can't reference the build date at the moment, with the truck at the dealership currently. I ordered it and it was delivered late August 2023.
-I was never notified by GM about any issues.
I'll update again on what the dealer finds.
I spoke with the dealership today and confirmed that we need a new main bearing and camshaft. Apparently, the shop foreman has been working on it, and the engine block is fine, so they'll proceed with rebuilding the existing engine. All under warranty and no concerns there, and they've been more than great to work with, beginning with putting me a Sierra as a loaner.Thanks for the follow up.
Dealer should be able to confirm if this was in the VIN window of Oversize Lifter Bores. Might make sure they check as I am not 100% sure if they would be automatically flagged.
It seems if the 6.2 gets past 7500 miles, the next danger window seems to be between 25,000-35,000.
What is your approximate percentage of City vs Highway driving?
The failures appear to be from a bad "batch" of parts that are out-of-tolerance. It's not a design issue per se. So, the hope is that those bad parts are no longer being used (and haven't been used for a while now) -- but no one seems to know when the bad parts were first used and last used.Will there be any changes to the 2025 6.2 to prevent any major engine failures?
And they don’t magically happen at the same spot every time or nearly every time.Bad batches of parts don't last for years. They are also traceable, lot to lot. Evidence doesn't bear that out in this case.
What's the "evidence" here? It's been suggested (by way of that customer satisfaction letter that no one actually received) that GM thinks it knows the general range of engines that these parts were installed in.Bad batches of parts don't last for years. They are also traceable, lot to lot. Evidence doesn't bear that out in this case.
What is the "same spot nearly every time" you're referring to?And they don’t magically happen at the same spot every time or nearly every time.
The broad evidence is this..... It's been going on since the 21-model year. Various engine failures that result in tear downs to replacements. Both V-8's. 5.3's to a lesser extent.What's the "evidence" here? It's been suggested (by way of that customer satisfaction letter that no one actually received) that GM thinks it knows the general range of engines that these parts were installed in.
I don't pretend to have THE answer(s) here. I'm not even playing devil's advocate or anything. This was just my understanding of the situation to date.
The same bearings are the culprit.What is the "same spot nearly every time" you're referring to?
That seems to point to bad bearings, right? (That’s what my local dealer tech thinks anyway.)The same bearings are the culprit.
I believe it. I’m not suggesting that it’s only a supplied-parts issue— just that that’s what I’ve heard and read about being a (if not the) prime factor.There is more to the story. Understand that the front main bearing is the next to LAST bearing in the oiling path and #1 rod bearing is the last as it is oiled from the front crank bearing. If the #1 rod bearing gets hot, it can then transfer heat to the #2 bearing. The best bearings in these positions will not survive if there is a lack of lubrication. There are other contributing factors to what is going on.
Unsure if the 2025 models will be "fixed"???
There were some suspect bearing issues, but this should have only been around 2021-2022 MY??
Then there was the "Oversize Lifter Bores". There is supposed to be a VIN range on these but it has never been released publically that I am aware of and GM was "supposed" to send letters to customers that may have been impacted. I recall this was 2022-2023 MY? If a dealer has a specific VIN in for other repairs, it was implied that the dealer should hold the vehicle and replace the engine. I have not heard anyone say they have been in any of these situations.
There have been camshaft and lifter problems, have not heard much about this isssue as of late. Maybe the engines are failing before the lifters and camshafts have problems??? Maybe the lifter and camshaft issue has been resolved?
Have seen a small number of engines where the piston wrist pin retainer was missing or not properly seated, piston pin walking, causing the piston to wedge in cyliner and in this case usually a connecting rod breaks. Again, not sure this is a large scale issue.
Unfortunately we have even seen newer build date replacement engines fail shortly after installed or within 6000-12000 miles. Unsure why this has happened.
There are a number of other suspected issues, GM has not mentioned these, but some folks are looking into some areas of concern. Unclear if these issue are confirmed contributors, but there could be some action owners could try and take to counter some of these concerns.
Bottom line, all you can do as an owner at this point is change your oil before or when the OLM hits 25%, do not warm up the engine without driving the vehicle as this leads to excessive fuel dilution in the engine oil, check the engine oil every other fill up, run Preminum fuel, and strongly consider something other than 0W20 engine oil, either 5W30 or 0W40, especially if you tow with your rig.
Other than some superseding component part numbers the engine hasn't changed since it rolled out in the summer/fall of 2018. Lifter p/n changed in MY22 but unsure what actually changed. They're listed as backward compatible to all DFM and AFM engines now.I believe it. I’m not suggesting that it’s only a supplied-parts issue— just that that’s what I’ve heard and read about being a (if not the) prime factor.
How new is this particular engine’s design? Is it new to the ‘21 models? If it’s much older than that, then has the 6.2 been failing like this for years and years (more than just the last four)? If it’s only just begun to fail with the ‘21 models, and the design changed starting for ‘21, then I could certainly understand it being a design issue. But then that would also suggest that EVERY 6.2 (since the design change, anyway) WILL fail… Right?
