Broke a lug nut stud.....WTF?
BOSS
The People's A D M I N
Dallas
I was pulling off the rear wheels today after a long drive and along with the nut came half the stud! WTF!? Anyone ever do this? How to fix?
:emotions122:
I am struggling to figure this out, it didn't break at the point on the stud where the nut sits against my 24s, but almost halfway off the stud it snapped. It was hard to turn the entire length of the stud.
Another lug was just as hard to get off the length of the stud, no debris on the stud except some metal shavings as I twisted the **** out of the nut off.
I noticed that the studs were very warm to the touch - could metal flex be that be one reason why these two things happened? Am I retarted?
:supergay:
BOSS
blueflamed03
Oklahoma
nope....drive down to a wheel shop, see if they can get you new studs pressed in....use antiseize on threads when installing your lugs.
BOSS
BOSS
Dallas
Thanks blue.
That's ******* gay.
:wtf2:
BOSS
Josh
Milwaukee, WI
I replaced three of mine on my grand prix last year. I'm guessing the same style pressed in ones. I had to pull the caliper and rotors off and then hammered the bad ones out the backside and put the new ones in. When I put the wheels back on with the new studs, the torque of the lugnut pulled the stud right into place. I just went to NAPA and got the studs. They were pretty cheap if I remember correctly.
BOSS
BOSS
Dallas
I know man, someone wrenched that sucker down last time :D
I wonder who that could have been :confused:
BOSS
---------- Post added at 06:04 PM ---------- Previous post was at 06:03 PM ----------
Gracias
tybardy
everyone needs a Hoe
Gilbert Arizona
oh man, antiseize is NASTY shit... gets all over the place and just ******* all around gross...
that is a really ****** problem man, let me know what it cost to get it fixed, just so i know if i ever run into this problem in the future
Rivieraracing
I always wipe a light coating of wheel bearing grease on the threads every other time I take off my wheels, I have broke off 2 different studs in my lifetime but haven't had a problem with a single one since I started with the grease!!
gbleezy
loves to snowboard
Were the lugnuts the correct size for the studs?
jmildoc
Indianapolis,Area
what josh said is true, easy fix if you can get everything off without twisting the tops off of bolts..AHAHA dont use anti seize,,,, just dont tighten them that much...I have been there plenty... If you didnt have 24's and a nice ride I would say you can ride with just 4 studs and be fine
jmildoc
Indianapolis,Area
i am just saying that there is no reason to really... I rotate my own tires on all my cars... have custom wheels on my car and previous cars and never have used it... im not saying not too i am just saying as long as you dont give yourself a hernia putting your lugs on then you shouldnt worry about using it... If you can get a torque wrench boss do that....
blue.. I had some KMC's on a car back in the day... they hold up well dont you think..
blueflamed03
Oklahoma
yea, love these KMC's, actually thinking of upgrading to some newer styles...these have been on for 2 years now, time for a change :D
jmildoc
Indianapolis,Area
too bad they arent 8 lug
---------- Post added at 08:49 PM ---------- Previous post was at 08:49 PM ----------
i am sure you can sell them on here in no time...
Man Van
As it's been stated earlier it's a simple fix. Hammer it out place the new on then tighten the lugnut and it will press in the stud. You should be able to pick up a new wheel stud for $2-$5.
BOSS
BOSS
Dallas
That's exactly what I did, many thanks to those who posted that including ManVan. You do have to take off the brakes of course to pull off the hub that holds the studs, just heads up.
The bottom line is, when you take your wheels off for ANY reason, you should run your fingers around the threads and check for any rough spots on the studs. If you have a significant rough spot or imperfection in a thread, you should SERIOUSLY consider replacing them before you end up where I'm at - (2) studs broken off by hand and (1) that I'm replacing because it's got rough spots. It's nuking futs. I have a lug nut stuck in my 4way now...had to buy a new one at OReily earlier. I'm replacing 4 studs on the right rear tomorrow.
My (2) lugs actually seized midway through the thread! They weren't on too tight so lock seize would have done probably nothing in my case, the threads were irregular after so many wheel removals.
Hope this helps,
BOSS
DESIGN
North Texas
Also, next time you remove your lugs hit them with some PB Blaster or other such product and let it sit for a couple of minutes. And for anyone who didn't know do not put them on with an impact driver EVER!
BOSS
BOSS
Dallas
JohanZ
