How to remove the "sail panels" "Appliques" ?????
Foggy
KS
What's the best way to remove what call the sail panels.. On my 14 denali it's the
black plastic pieces above the taillights next to the hatch door on both sides.
I'd like to remove them and fix/repair how they are mounted. One is really loose and
vibrates at the car wash.. Don't want to lose it !!!!
Noggles
They come off easily. I believe remove the taillight and then there are a couple screws that hold them in place along with maybe a couple clips. While they are off, there are a couple interior pressure vents behind them that sometimes break so would probably be a good time to put new ones in as well.
pretty easy to take off once you have the lights out of the way I removed mine to put the escalade style lights on instead
F
Foggy
KS
Thanks for the help everyone... Supposed to get up to 40* here tomorrow before the next
polar vortex F's us !
I'll pull em out and figure out why they rattle so bad !!!!
Just didn't want to break anything removing them
could try using some stick on foam padding in strategic places to prevent rattling, same stuff you might use under a gap in a door to the house or garage, cheap to grab a roll and trim to fit as needed.
F
Foggy
KS
I think I'll do something like that.. I've got some 3M automotive molding tape
that I may put in a couple of areas sparingly !!
Thanks for the suggestion
j91z28d1
3m sticky back velcro. the soft side works great for fixing rattles. anywhere I find plastic rattling on plastic, I put some and it makes everything better
sadly I've probably used 20ft of it inside plastic panels my c6 and only a few inch on the yukon lol. freaking plastic rattle trap in the shape of a car haha.
F
Foggy
KS
I used flocking tape in a couple areas and it helped significantly
Also Cleaned up all the crap and debris trapped behind the housings
and applique !!!
F
Foggy
KS
Ran thru the carwash after I did this. The rattling/vibration is almost
non existent now !!
