No power at all. - SOLVED
ny_summit
2007 Yukon Denali.
The other day I turn the key to acc mode. Everything powers up as normal. Once I turn the key to start everything completely died. Once I connected my battery jumper it starts and drives as normal. As soon as I shut the vehicle off all power is out again. The battery isn't dead. The only accessory I have on the truck is an HID relay harness. Can anyone help me ASAP pls as this is my family vehicle., it seems connected the jumpers "wakes it up"
Glad that you found a SIMPLE solution to your issue.
Was the cause of your issue do to user error? LOL
ny_summit
ny_summit
Haha I haven't touched it. I assume it worked loose over time? It didn't seem loose when I first took a look at it, I was stranded in a parking lot when it happened to me the 3rd time. I grabbed the positive cable and twisted it and saw the lights on the interior turning on. I got it to start and once I got home tightened it up and it's been good to go. I'm glad it wasent a bigger issue
your lucky, sometimes there is invisible corrosion in there, happened to my brother in laws truck, would mostly not start, voltage was good, pulled the starter and bench tested it, worked every time, went to loosen the battery cables and discovered a ton of corrosion between the battery terminal and the battery cable. could not see it while it was connected, looked perfect. sometimes the cables corrode on the inside as well and look fine on the outside
petethepug
Michael
SoCal
Check the cable again after your next drive. Verify it’s not excessively hot. If it’s damaged, the heat will let you know.
koomie98
