Small Coolant leak from hvac heater hose quick connector
Atrevino0497
The white heater quick connector which runs to the heater core is leaking when it gets bumped. It’s the second time this has happened and I’m tired of replacing them once a year. It drips on to cylinder 8 coil pack and I’m over it.
can I just clamp a hose on with a t connector attached instead? Just to bypass all the plastic junk?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Tags: Tee gruven suck
89Suburban
SE PA
could you just use some of these? I don't remember if they arw both 5/8s or not but yes. few clamps and done?
:deal:
And I quote the great Ayatollah dubalub: "3/4" heater core connectors and 1/2" rear heater core connectors. The hoses to the two nipples on the water pump are 5/8".
donjetman
Almost 5 yrs abd 50k miles ago I had a T break. I installed the billet aluminum Gruven Ts, and all new hoses and coolant, water pump $cha-ching$. Been good ever since.
https://www.tahoeyukonforum.com/threads/heater-core-t-connectors-broke.116171/
^^^^^x2^^^^^ That is your solution, if you cannot make the plastic Tees work. Hopefully, you used a GM plastic Tee and not a Dorman or other 3rd party plastic Tee when you made your replacement.
petethepug
Michael
SoCal
Ah yes, generic overseas parts. Even if they’re guaranteed for life and cost 1/2 as much, it doesn’t mean Jack when you’re crossing the desert and hit traffic when it’s 115* ambient.
That’s the standard I maintain our vehicles to, a weekend drive to Vegas during Summer.
Atrevino0497
Atrevino0497
Thankyou everyone for your recommendations. I remember @Geotrash telling me to replace these a little over a year ago after breaking one putting my engine cover back on after replacing the alternator.
This time I was doing injectors and checking my plugs and started seeping out before the firewall. I went and put another one on all seems well. For now that is. I drove it about 600 miles since and my coolant went down just a smidge after replacing and I topped it off.
My Tahoe just hit 147k miles. I’d like to keep her on top condition for many more years to come. Next replacement is going to be the trans cooler lines and auxiliary cooler line. And oil cooler lines also. They’re starting to seep from the crimp fittings.
Is it possible to redneck that job or better off to replace?
petethepug
Michael
SoCal
Neck it until you get OEM from Rock auto or Gruven. A trip to the plumbing store to grab some copper fittings and hose clamps will get u by.
89Suburban
SE PA
He got himself a new lady a while back, so that's probably taking up most of his spare time. Good on him!
Atrevino0497
Atrevino0497
Sorry again for the late reply, my company just laid off 110 people and those of us left had to pick up some slack.
As of now they just appear to look wet. But I’m definitely going to get new oem ones from rock auto.
Going forward .. my truck has 4wd. Will I have to lower the front diff to feed the oil cooler lines through or will there be enough room with some wiggling ??
As far as the aux trans cooler. Instead of taking the bumper off. I plan to just take the passenger headlight out and grille
ScottyBoy
Shreveport, La
I replaced both T connectors and quick connectors on my 2001 back in 2017 before I went on a 3,000 mile road trip. I used the Dorman brand connectors from Rockauto. I just had to replace one of the quick connects again last year. I should probably replace the rest of them just to be proactive.
KC 2013 Tahoe
Chandler, Arizona
ScottyBoy - The Dorman and other aftermarket connectors seep/leak, usually from the very start. The only connectors worth using are either the OEM GM Tee's or the metal ones from Gruven Parts. I've stuck with the OEM as they're so easy to swap out and readily available.
I replace the Tee's every 5-years along with new coolant and all the radiator, heater and various bypass hoses as preventative maintenance. Beyond 5-years the plastic Tee's aren't trustworthy. I live in Arizona with summer temps routinely above 110. Our Tahoe is my wife's daily driver and regularly commutes 30 miles daily, plus a 600-mile roundtrip across the desert in July heat from PHX to San Diego (I-8) for our annual summer vaction in Carlsbad. Have never had a broken/leaky tee or bad hose following this schedule.
Be sure to 'tag' the target of your response by typing his/her name starting with the "@" symbol, then select the right member from the dropdown list of members. Like this: @KC 2013 Tahoe (you will have an alert to view). That way an alert is sent to that user that he was tagged. I'll tag @ScottyBoy like this so he's aware of your prior post.
An alert is also sent if you "Reply" to his post like I did yours here.
Generally speaking, no tagging is needed if the poster is the Original Poster (OP). Hope that helps.
KC 2013 Tahoe
Chandler, Arizona
Thanks - Got it!
Kevin
mikez71
Don't need to lower diff, just need a little room underneath to pull the line up from the backside.
Slowly snake the front two hose ends through where you need to pull it. Takes a little doing, but won't take long at all!
Cheap heater T's.. I went with SKP because they were in stock (and cheap).. planned from the start to replace with factory T's before long..
Have less than 2 years on them so far.
Woned2004
