AC Diagnosis?
EddieC
2008 Tahoe;
Today our air conditioner blew nothing but hot air even though the hvac display light was on.
We've never had an issue with it before and it generally blows icy cold, at least in the last memory of serious,y using it. I say seriously because we are just coming into the season but the auto settings turn the ac on frequently. It has never needed attention in the past.
I checked three fuses and swapped out one relay, all which appeared ok, then upon closer inspection I found the compressor clutch engaging for only 3 seconds and then running 12 seconds disengaged, then repeat and repeat when the ac was turned on.
I ran out for a recharge kit and on the initial test the gage showed needing a charge. Using a 20 oz can it took most of the refrigerant but did get in the green zone on the gage near the minimum acceptable pressure of 30 psi.
Once the charge was started to be applied the compressor clutch would stay engaged as it should.
Now the air from the ac vents is cool, not cold. Took it out for a ride and it seemed a bit cooler, but again not cold as I remember. There was a definite difference between ac off and ac on though.
Fingers crossed that it holds the charge in the coming days. I am not understanding why it doesn't seem as cold as it seems to have been all (?) of it's previous long life.
Any input would be appreciated from those who have been through it or are familiar with the system.
LordWayback
short of running some dye in there you could change out the valve cores next time it gets refrigerant
LordWayback
It sounds like a slow leak getting faster over time you should get a dye kit with a uv light and add dye with the next r134a fill up and check all the common places, pulley shaft seal, compressor body seal, condenser, where the fittings meet and if you have rear AC check in the inside of the passenger rear fender liner with the uv light sometimes the rear ac lines like to catch road salt and corrode there or the hangers wear them out otherwise check the evap drains if either Evap drain has dye (with rear ac) then you have a expensive repair job to make as it indicates the evaporator cores being bad
EddieC
EddieC
Thanks for that.
I never knew that the rear ac was more than just ducting.
This is going to need a video search.
opfor2
Riverside County, CA
If you look under the vehicle by the passenger rear wheel well you can see where the coolant hoses and refrigerant hoses go into the rear evaporator box
Rear AC connector
EddieC
EddieC
I haven't been able to get back to mine but hopefully soon.
EddieC
EddieC
Correct, also in the wheel well there are plastic clips on the frame which is where the rear lines typically leak
I saw a video using JB Weld for repairing a leak. Ever try that?
mikez71
There is an evap in the rear. The photo's are showing the lines to it.
It intakes from the backside of the unit (facing quarterpanel sheetmetal)
which seems to do a pretty good job of keeping dust out..
EddieC
EddieC
Resurrecting this to ask about the dye.
I've seen it both in a recharge can and in a little bottle of just dye.
Who is it introduced in the system if in the dye bottle?
opfor2
I added about three oz to my system that was empty, evacuated the sys for about an hour added the r134a and found the leak and repaired. Added the dye with a syringe through the Schrader valve.
EddieC
EddieC
Special syringe to use with the valve?
Specific tool for the application?
EddieC
EddieC
This is the specific clip where the lines like to fail inside the wheel well 99-modern rear ac i believe all run a similar clip design
Is that or any of the other mentions behind the inner fender liner or just behind the rocker panel/frame rail?
IS the green color the from the original fluid leak or was there dye introduced?
