2023 Stock Z71 with 285/60R20
Spanman
Massachusetts
Love the Copper look.
Did the tire size or brand change, give less of a smooth ride on hwy?
Did it change any built in Z71 digital controls?
Did you try them in the 4wheel drive mode yet?
Thx in advance
I
IronWill42
Thx in advance
I have not noticed any change in driving manners on the highway. They drive pretty damn smooth. It did not change any built in controls that I can tell but I have not used 4WD since putting them on.
TrueAt1stLight
Minneapolis
What pressure are you running? I purchased a set of BFGoodrich AT’s in the same size and was told by the tire shop I should be running 50 psi or more in them to avoid cupping.
nick14226
You do need higher pressure because you went from SL’s to LT’s for proper load carrying. Cupping, don’t know about that, and 50 psi sounds high, but in the 40’s is typical. These guys made it easy so you don’t have to look up the new pressure on a load chart.
TrueAt1stLight
Minneapolis
AMAZING!!!! Thanks for that tool. Wow, is that helpful.
Dbow555
New to the Forum!
Great information on the tire size upgrades to 285/60/20 with the Cooper AT3 XLT.
Currently have a 23 Tahoe Z71 (without the air ride) looking to get the Newer BFGoodrich TA KO3 tires. Problem is that tire does not come in the 275/60/20 yet. Is there a chance that the KO3 in 285/60/20 on the stock rims could cause a rubbing issue? (On Control Arm based on width, or at full locks with Husky Liner Splash Guards)
Looking for some experiences or other things I may be not thinking about before I spend $1600+ on a set of tires that may rub.
Also, did notice that the OEM SL Goodyear Territory ATs had a slightly larger diameter than other 275/60/20 tires.
Thanks!
Bergs22
New to the Forum!
Thanks!
What did you end up doing? Currently considering KO3’s
BacDoc
Vero Beach Florida
You have a Z71 with awesome wheels and off road tires and you haven’t taken that beautiful 4WD off road?
Shame on you!
I would have taken it off road the first chance I got!
Those tires on your rig look solid and ready to rock off road - get her in some dirt asap!
RobK
