2023 GMC Yukon AT4 6.2L dead at 10K miles
tj40371
I was at delaer yesterday, asked my salesman what their fail rate they have seen on the 6.2.
He said the dealer as seen two of them in last 3 years, out of about 300 trucks. One was a Sierra, one was a Yukon. Both were top end/lifters.
His opinion from what they have seen and in talking to field rep and other dealers, is it is about a 1% problem. Which he said is "within the normal production expectations of GM"
My dealer service department said the same (and they are a very high volume dealer). The forums seem very scary about these 6.2L engines but they sell how many of these a year vs. how many reports we see on this forum?
I'm up to 14k miles on our 2023 and expect to run it up to about 75-100k before potentially looking at a replacement.
D
Dangler6131
My replaced engine should be finished today. Will report back. GM not offering a buy back.
Geotrash
Dave
Richmond, VA
That's great - less than 16 days from tow to new engine. Bummer about the no buyback, but doubt you'll have another failure for as long as you own it.
tom3
I wonder if this a new engine, a long block, or a rebuild? Sure a shame to do a heart transplant on a brand new premium machine.
D
Dangler6131
Here is another question - is an exhaust smell normal with a new replacement engine? When it idles it smells like an old car
D
Dangler6131
Unsure. Here is what work order said
StephenPT
St. Helens, OR
Lots of oils and greases are on the outside surfaces of a new engine. It takes a few hundred miles for it all to burn off.
tom3
That work order is pretty confusing, various engine parts but repair description for an electrical problem?
D
Dangler6131
This is fairly noxious. Will give you a headache bad. Taking it back to dealer Monday. I cannot overstate how unhelpful GM has been on this whole affair. I have bought seven vehicles from them in the last 12 years and the most they have offered is an extended warranty on my replacement engine.
stevedonato
Gov't standards are one thing - the tests are anachronistic, and do not come close enough to represent real world driving.
CAFE MpG tests explain undergeared axles for decades, followed by smaller engines with less cylinders mated to 8- & 10- speed transmissions.
That said, my suspicion is GM went ahead with V8-V7-V6-V5-V4-V3-V2 mode because they don't want the engine to last TOO long.
That extra complexity is gonna bite them in the arse when Mexico's used car market hemorrhages into the southwestern US.
GM tried this in the early 70's at least with the Oldsmobile. It never workedr and dealers would make the change to disable it and keeping it running on all 8 cyls. Remember at this same time GM produced Gas V8's running on Diesel fuel another disaster that never worked. Time for GM to learn from japan.
stevedonato
Thanks for the mansplain. I long ago gave up trying to guess every presumption someone might make to one of my posts and trying to account for it up front. Yes, of course I understand WHY AFM/DoD exists. What I'm trying to convey is that it doesn't actually result in a meaningful benefit in the real world. Ergo, the regulators are forcing this down our throats and it's a farce.
Do you think a customer cars about saving a few bucks when buying a $85K GMC Denali?
B-train
If it smells like an old car with no cats, then I would assume the flex and ball section of the Y pipe isn't sealing properly. You could scoot under and look for soot trails at the connection point. The only spot you should find soot is on the tailpipe.
