K2 Kaiju
The Depths
HMM I have never had a issue with installing sway bars with just a jack
both the front wheels have to be off the ground to release tension, rear wheels have to be on the ground to release tension so use ramps.
for me it's always been a piece of cake
rear is super easy
front you just put 1 d bushing on loose, then the 2nd d bushing on loose, attach one end link loose, attach other end link loose. tighten everything up done.
I used ramps each time so thats probably my problem (and Im old). I could get the frame bracket screws started, but all of my 16mm sockets were too thick-walled to get on the screw once it was halfway in. One arm holding bar in place, and other trying to rachet was craptastic. Using the old screws and a 10mm 1/2 impact made quick work of it. Back was easy since I didnt even try new screws...
if the wheels on the front are not off the ground then you are fighting the sway bar, even with 1 wheel off the ground you are still fighting the sway bar
both wheels off the ground, with frame supported allows the control arms to lower and release the sway bar tension.
the front sway works with wheels on the ground (constant tension), the rear sway bar works when there is sway and the body moves or lifts applying (counter tension)
Thrust
ICT
You're better off not using the Hotchkis supplied hardware. It's cheap and will rust very quickly. If you feel like replacing the GM hardware get some A2-70 Alan head chrome bolts. They are metric.
K2 Kaiju
The Depths
Started adding speakers, amp, sub to my new K2, then stopped after putting in the kicker ksc270 speakers to the corner dash locations. Somehow the tiny 2 3/4 speakers completely changed the whole sound. More clarity, volume, and bass with less distortion - and not just a little improvement. It has to be the crossovers lending power somehow back to the door 6x9s. Best $60 mod I have ever done - just beware, they look like a joke...
k_arnold72
If you have bose(possibly even if you don't), the speakers you removed were 2 ohm and the kickers are 4 ohm. So the amp is sending them less power
K2 Kaiju
The Depths
That could be why they work so well - maybe sending more pow to the others speakers? The bass is so much better - not necessarily from these speakers - but as a whole. The stock corners are overdriven and trash everything. I had put in some 2 ohm coax in the doors on my burb, but all I got was painful treble with no bass (I left the stock corners). Had to add amp, sub, and still probably still needed another amp to drive the speakers. This is just right for my needs now, and I dont want to mess up the balance. Also save the space sub was gonna take in this shorty. Was a little bit of a PITA getting at the screws that close to the windshield, but worth the effort. Those little capacitors on the positive lead have magic fooseball in them while the bose corners are the devil...
k_arnold72
Yup, frees up more power that the amp can send to the other speakers. I had a similar experience. I replaced the 4 door speakers with infinity kappas. Which are 2 ohm on paper, but when I put a multimeter on them,
the bose speakers were lower in actual resistance. I lost a bit of bass, but I'm just living with it till I add a four channel amp to the doors and replace the bose sub with a beefier(also amplified) 6.5". And yeah the top two dash screws are a PITA.
does anyone know off hand if the silverado mirrors will fit on the tahoe/suburban? I saw it mentioned somewhere but not sure if it's possible or not.
RST Dana
OH
Esky. eBay has a boat load. Just make sure they have everything you currently have I.E. puddle, heat, blindside, turn.
K2 Kaiju
The Depths
Did rear dif and transfer case fluids. TC took 15 min while rear was 90 since the spare tire needed cleaning and filling (was @ 20 psi). The dif cover removal is such a time waste. Fluid actually looked good and it only needed a plug clean. Next time Im installing a new cover with a drain...
the 18th letter
Northern New Jersey
Got ready to give my truck its 1st oil change since I got it and thankfully saw I needed a new gasket for the oil pan plug before I got started. Got back in time for it to start raining lol. The oil filter is set up in a way where it makes no sense to not prefill it before putting it on so that’s a plus.
Sparksalot
Bastrop County, Texas
Plug gasket? Seriously? Just like 1940.
