Took a vid of the new starter sound. I'm convinced it's spinning the engine faster. It starts a little quicker. Supposedly, it's only a 1kw motor:
After I cleaned all my battery connections and got the new starter battery put in, mine sounds about like that, but I'm still going to put the new 1.7 KW in sooner or later.Took a vid of the new starter sound. I'm convinced it's spinning the engine faster. It starts a little quicker. Supposedly, it's only a 1kw motor:
I put the filter in mine many moons ago, but I still get this very dirty smell switching between AC and vent.Finally finished the evaporator core cleaning and cabin filter retrofit-
Bought a piece of 16" thin PVC pipe (some kind of pre-made sink connector piece) then softened it with the heat gun to flatten it. Ugly but very functional. Taped it to the shop vac with painter's tape cuz that was the first tape I could get my hands on and I didn't have many fcuks left to give with this project:
Still looks gross but it's a lot better than what it was and I was over leaning into the floorboard at this point:
Holding filter in place for the pic:
Closure installed.
I left the blower on high with all vents closed except for the one on the far right of the dash so I could reach it to feel. I didn't notice any excessive reduction in volume out of the vent. Doesn't matter, it's done. Spent most of the time getting that screw in front of the subwoofer installed.
Need to clean the evaporator one of these days.
It almost sounds like a starter from a 6.2, like mineTook a vid of the new starter sound. I'm convinced it's spinning the engine faster. It starts a little quicker. Supposedly, it's only a 1kw motor:
I don't remove that screw, just loosen it. Still allows the cover to be rotated/swung out of the wayFinally finished the evaporator core cleaning and cabin filter retrofit-
Bought a piece of 16" thin wall PVC pipe (some kind of pre-made sink connector piece) then softened it with the heat gun to flatten it. Ugly but very functional. Taped it to the shop vac with painter's tape cuz that was the first tape I could get my hands on and I didn't have many fcuks left to give with this project:
Closure installed.
The cut off scraps are used as plugs or just pieced and melted togetherWhat'd you use to fill in the gaping holes- cut pieces from the tubes?
Thought it was in my head…. And it probably is but the reman I got from RA when mine went in the beginning of summer, I swear, I noticed it spins/starts faster and has a slightly diff tone….then again, it was 10 yrs old and subjected to salty goodness of the NE roads for said 10 yrs….Took a vid of the new starter sound. I'm convinced it's spinning the engine faster. It starts a little quicker. Supposedly, it's only a 1kw motor:
I left the screw out completely, the 3rd time I took it out...beat thatI don't remove that screw, just loosen it. Still allows the cover to be rotated/swung out of the way
I thought about doing that also, but thought it might cause a rattle or something.I left the screw out completely, the 3rd time I took it out...beat that
SameI left the screw out completely, the 3rd time I took it out...beat that
No rattles hereI thought about doing that also, but thought it might cause a rattle or something.
I do know that my 1/4" drive Craftsman ratchet along with a 1/4" deep well socket fits perfectly/is correct length to go up in the hole and between the trans hump to get to that screw. I usually don't have a problem getting to the screw with a tool, but I have a problem getting the screw lined up with the hole up in the recess to be able to screw it back in
SameNo rattles here
Yeah, I noticed that on RockAuto when somebody mentioned the 1.7 starters, I've decided to check the 6.2's and sure enough, there it was.You guys were talking starter motors and I googled and did indeed see that the 5.3s use a 1.4 Kw starter and the 6.2s use a 1.7 Kw starter. Learn something new everyday with these things. Unfortunately, I cannot remember where I saw y'all posting about it.
I tell you what, accidentally bought some rotella t6 15w40 instead of 5w40... My goodness is the oil pressure reading much happier numbers. Idling at 25, and driving normally immediately shoots up to 35, and then 45. Maxing at 53 and actually dropping down to 51 at 6,000.
Is it necessary for anything? Absolutely not, do those numbers make my brain happier, yes, I might just run 15w40 for the rest of this engine's life.
