Skid Plates for our GMT900s?
Charlie207
LFOD, New Hampshire
Nm. I found it on eBay, they're around $230. They sure look nice, but that's over my budget for now. I wish there was something with a similar design - it's similar to the plastic splash-guard's shape - but not so $$$.
T
tgui
I paid about that. Yeah its a bit $$. Great build quality and at least I don't have to worry about cracking the plastic one again!
Charlie207
LFOD, New Hampshire
Yeah, it's an upgrade from plastic.
I ordered the two other plates, and some bolts. For the transfer case plate, are there pre-existing holes in the cross-member, or will I need to drill & tap them myself? @Geoffsfas10
St. Louis
The holes are there, just needs threads. I used one of the front plastic splash shield bolts to cut the threads then used store bought yellow zinc plated bolts. The factory self tapping bolts are pricey, unless you grab some off a vehicle at the scrap yard
Charlie207
LFOD, New Hampshire
I have a tap in that size. I also bought a 10-pack of bolts, so I can turn one of those into a ghetto-tap of I need to.
Are the factory self-tappers tri-lobed?
St. Louis
Not sure off hand.
When I bought my shields I was going to order factory bolts too, but they were about $7-8 each. I didn't want to spend $60 on 8 bolts, lol
Geoffsfas10
St. Louis
Hey sorry i missed this, i never got notification, but just like stated above, i pulled a bolt from the front plastic skid plate and just ran it into all the holes, and then used some stainless hardware in the proper size. worked fine, they are still under there and its been a while.
Charlie207
LFOD, New Hampshire
No worries. I had a spare M10x1.5 bolt that I used to drive up into the four factory holes, then used some new 25mm bolts to mount the skid plate. Easiest work I've done on my Yukon to date.
JohanZ
