Jerryrich0806
- Joined
- Feb 12, 2022
- Posts
- 47
- Reaction score
- 12
I have a 2011 tahoe ppv. Ac blows cold but I have to turn it wide open to feel it. Any suggestions?
Explain pleaseMost likely a damper operational issue. @swathdiver
Does the blower motor move a lot of air? If not, have you verified that it does not have a clogged cabin air filter? If you are not the original owner, it is possible that someone installed the kit. There are actuators that control the temperature, where the air is directed to and where the air comes from. Any or all could be an issue and this is best solved with a Tech-2 to pull any internal BCM codes and to test the blower motor.I have a 2011 tahoe ppv. Ac blows cold but I have to turn it wide open to feel it. Any suggestions?
Yes a 2011 ppvWas it a canine unit by change? there may be fur blocking airflow at the evaporator coil. If you don't have a cabin air filter already, this is a good time to add one, then clean the coil while you're doing it.
