89Suburban
Bull in the china shop
SE PA
avalonandl
Troy, MICH & Naples, FL
Sparksalot
Bastrop County, Texas
Just Fishing
Can't fix stupid
Utah
89Suburban
SE PA
This is the one I’ve had a few years. Supposedly works for GM or Fjord. It’s kinda picky. I’ve found the best way to get it to trip a sensor is to hold it vertically oriented with the back side flat against the tire.
Can you take a picture of how you orient it on the tire for me? I didn't lay it flat, I pointed it like a gun. I tried through the rim, at the stem tip, and through the tire above the rim.
I do mine with that black tip pointed against the tire right below the valve stem. Make sure the battery is good!
Fubar0715
Scott
Southern New Hampshire
I put mine near the valve stem pointing up - flush against the tire or rim. Took a little trial and error (ie...patting my head and rubbing my belly) to get the right combo to work.
rjhorst14
