Credit card fell in gap of center console cover
Reels
Senior Member
Tossed my credit card on top of pile of stuff by phone charger and it slipped in the crack by where the wooden cover folds in.
Anyone know if it is easy to take apart to retrieve it?
Thanks!
tom3
Got mine replaced like this a couple years ago, just log in and click on the icon.
StephenPT
St. Helens, OR
This video is about installing a wireless charger on the center console lid, but in order to install it they nearly take the whole console apart. Maybe it's enough removal steps to get you to the card?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Depending how it fell in it MAY be laying right in the bottom along the carpeted center hump where it meets the side of the console. You can pry out on it to see if it slips through. If it does buy a lottery ticket asap.
Thanks!
bang on it a few times real good it might just fall out the bottom
pictures of where it fell in might be helpful
Mastyla
You might try using a thin tool like a butter knife to gently pry the cover open. If that doesn't work, consult your furniture's manual or a professional to avoid damage.
This is exactly what helped me to solve this problem :)
Btw, I looked through the NetSpend reviews later and I wasn't alone. So, sometimes banging is the best way out, though it even sounds weird.
as long as there is a place for something wedged to come out the bottom then banging on can work, not unlike when a chip bag gets hung up in a vending machine
BigdawgR6
That area ate up a whole Starbucks straw somehow. I watched it slide in slow motion and was too late on catching it before it fell. My main concern was the slider would open successfully anymore but, it did. I was impressed to say the least lol
mathetas
Thanks!
Although I understand this was likely resolved long ago, this same thing happened to me with a government issued ID. I used the video posted by @StephenPT to literally take the console apart (in a winter storm at night), but if this happened to me again, I would do the following with the knowledge of how the cupholder works…
1) Remove the passenger side lower and upper trim panels per the video. To avoid scratching the console, you can move the console to its most rear position(if you have that feature). Otherwise, per the video, have a helper pull the seat bolster away as you jimmy the trim up and out—clips are sharp.
2) Using a flashlight or headlamp, look under the cupholder. You will see a metal tray UNDER the plastic molds for the cupholder. Your card is 99.9% laying in there. Small arms or hands are better, but if you want it, that is where you get it. The hope that banging the console will knock the card off of the tray and onto the carpet is not misplaced, but given what I saw, it would need a lot of luck to jump the tray—especially with the low clearance between the tray and cupholders.
I took everything apart only to realize I could have saved myself a few hours, stress, and some bloody knuckles. Hope this helps the next guy!
JohanZ
