Calling All Tech-2 Owners...
kbuskill
NE. FL.
Well, has anyone figured out how to, or if we can, change the tire size on the GMT900s with the Tech 2?
It seems like it should be possible with the Tech 2, I know I can and have done it with my Diablo tuner but was trying to do it from the Tech 2 and never could find a menu for it.
I successfully changed my TPMS pressure settings but couldn't find tire size.
I know when I was flashing a used ECM, using TIS2000, for my buddies '01 Suburban it gave an option (within TIS2000) for tire size while I was making the selections to set it up.
I was in there changing the tire sizes on the wifes 05 I haven't tried it on the 12 I would imagine it can be done though, I was trying to do it on the 05 to see if I could get a funky tpms sensor to work with the other 3 but it was to far out of range
kbuskill
NE. FL.
Well if you get a free minute try it on the '12 and let me know.
I wonder if you "build" the truck in the Tech 2 menu as, say a 2006 if it would let you do it.
I tried changing the tire size in my 03--I found the menu, selected my tire size, but it wouldn't let me do it. I tried doing it without the candi module.
Nope, no menu option for it for the 900s.
crownvic31
Hello all
I know this is 2 years old but i figure i just ask it here i stead of starting a new one.
How do we go about getting the options
on a tech 2 to change the tire size on a 2007 escalade?
Hello all
There is no option in the Tech-2 to do so. You can only select the tire type and air pressure in the RCDLR module. I had BlackBear change the tire size when he tuned the Sierra.
Well, I might be wrong as I just seen George's post up there! Check it out and let us know.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I think there are limits to what you can select. I can check on my ‘13.
DefiantOne
