TBC fuse parasitic draw
Bjbmacon
Hey guys! New here. Thanks for the add to the forum.
I have a 00 Tahoe that I’m getting a draw on the tbc fuse in the under hood fuse box. It’s enough to kill battery in about 2 days. The draw is around .83. I have pulled everything I can think off to stop the draw and nothing stops it. I have pulled ecm,bcm,cluster,radio,hvac controls,on-star modules,light switch,seats,airbag,all rear hvac actuators and blower module. I know that looking on Mitchell wiring diagrams that fuse has 4 circuits. Bcm, keyless antenna receiver and the light switch plus the high low switch. The keyless receiver was missing when I got the truck. I’ve disconnected all other sources. Any help would be highly appreciated!
MassHoe04
Western MA
A few other GM truck forums had people looking at ignition switch as possible source. They described a 0.8 draw on the TBC fuse while this was happening.
Our resident electrical experts can help walk through your issue...
I am sure you will get directed to search up "Parasitic draw" threads on our forum, since you are not the only person to see this kind of thing.
Do check those threads out. There are a lot of great step-by-steps on what to look for in diagnosing electrical draw issues.
Also suggest checking for the "usual suspects" (or at least rule them out): main ground points to engine block and on the body mount (under the driver's side door), battery cables, battery connections, etc.
Inspect, clean and tighten all ground connections. Bad grounds can prevent the BCM from shutting things down completely and stay in "sleep mode", drawing power on things like radios or HVAC controls. BCM is supposed to exit sleep mode and completely shut shings down after the programmed time of inactivity. Bad ground can prevent that shutdown from happening.
Check connectors at the BCM and wires you can see along your various harnesses. Maybe a low volt wire grounding out. Not enough to blow fuse. Could be a wire from the BCM to another component that draws low amps. Not enough for a fuse to blow, but enough to draw power.
Just some thoughts. Look for anything obvious at least...
Welcome to the Forum from NH.
Pics of the truck, please.
Bjbmacon
Bjbmacon
rockola1971
Indiana (formerly IL)
Pull connectors on BCM and then reattach when you are ready to drive 24hrs or overnight later. Might have a bad BCM or its just going to sleep then its grounds for you. Check for corrosion, broken wire or the growing green suff on ground at rear of engine to firewall AND also check the bundle of grounds on drivers side chassis under driver door up near where the firewall starts. Wouldn't hurt to go ahead an remove bolt and wire brush chassis point, bolt and terminal lug on wires.
Mistehkins
