Places to mount gauge pods ?
Supercharged my 2019 Tahoe and I want to add a boost gauge and a fuel pressure gauge to the interior. If anyone has mounted gauge pods in their interior and has any good recommendations for products or ways of doing it please share. I’d ideally like to mount them on the A-pillar but it seems no one makes that for our trucks.
RB_Trucker
Redondo Beach
You might need to check to see if a pod setup for a 2015-2019 Silverado 1500 or HD models will work, I’m sure the A-pillar is the same in both the trucks and SUVs.
B
Nice! Thanks for that. Any idea if this one that says it’s for up to a 2018 model year would work in my 2019? I don’t think the interior changed at all from those two years. That was the only dual one I saw without the handle for a Tahoe.
Thrust
ICT
I would assume it would work. I have the single pod A piller from them that I still need to put in.
You might cross reference the part number for the A piller trim between yrs.
B
Would you happen to know where I could install the fuel pressure sending unit for the gauge? I have a 5.3 with a 2.9 whipple.
Thrust
ICT
No clue on that one. Did you change pullies?
I've read people upgrading the HP fuel pump, but that means pulling the supercharger. Ugh.
B
Yea I went from a 4.5 to a 4.25 and installed lt4 fuel pump and lt4 injectors. I believe that my hp fuel pump is still stock. Someone told me in another forum that I could tap into the fuel supply line on the drivers side of the engine towards the firewall that sticks up but i don’t know how those fuel pressure readings compare to what the injectors are actually getting. I think it should be fine though because the reason I wanted a fp gauge was to be able to look out for drops in fuel pressure which I think the supply line would show me.
firedog9518
