tekfire07
- Joined
- Sep 27, 2022
- Posts
- 56
- Reaction score
- 42
Okay quick question for the people running Amzoil in their trucks. Which grade of Amzoil do you use and how many miles are you getting between oil changes?
I use Amsoil in everything I own. Bikes, sleds, cars and trucks. I was always a Mobile 1 person until my Denali threw a rod. I don’t blame the oil, I blame myself because I got lazy and had Walmart change my oil because they did it using Mobile1 cheaper than I could do it myself. Did they start the truck before they put the oil in? It’s possible. 3 days later I’m towing home from Wisconsin with a window in the side of the block.
I went to Amsoil after that and haven’t looked back. I change my oil at 5k miles and pull a sample every other oil change for analysis. Flying colors every time and am told I can extend my change intervals. But I don’t.
I am a preferred customer so I get it cheaper than off the shelf when I order it. I always keep enough for a few changes on hand and get free shipping. My truck takes 3 gallons every oil change and that right there is enough for free shipping. I use their gear lube, grease for my sleds and even have their air tool oil.
My biggest thing is, use whatever you’re happy with, full synthetic is best but never skimp on the filter. Filtration is key. Stay away from Fram sure grip, they are garbage.
I've been an Amsoil preferred customer since 2009. Amsoil and HPL brand oils IMO are arguably the best oils, but they come at a $price$ IMO if you're doing normal oci (oil change intervals) don't waste your $$$. For xOCI (extended oil change intervals) these super premium oils make $cents$.Okay quick question for the people running Amzoil in their trucks. Which grade of Amzoil do you use and how many miles are you getting between oil changes?
I run the 5w-30 XL in my Escalades. Transmission I use Pennzoil in my trans on the 08 Esky but use Torque Drive Amsoil in both my Duramax trucks. Only reason I went with Pennzoil in my 08 is because that’s what they wanted me to use for my warranty.Which grade of Amsoil oil do you run in your engine? Do you also run it in your transmissions? I see 3 different grades, Signature, XL and OE.
The manual calls for 5W30 with GM6094M (aka dexos1), and Amsoil XL has that spec. Over here in Europe it is quite affordable at 8€ per quart.I run the 5w-30 XL ...
