High pitched noise from stereo
petethepug
Michael
SoCal
Good Q, what type of BT are you running behind the dash in the harness?
Have u tried undoing it to see if the annoying sound stopped?
U
ukrkoz
Auburn WA
CRUX BTGM-33 Bluetooth® Interface​
Talk hands-free and stream music through the factory radio in select GM vehicles​
or very similar. It all worked fine for almost a year... was pain to tuck behind the head unit.. I'll try ground cables first.
IMO, you've got a ground loop issue coming from either your your BT adapter or your head unit. First, check to see that all of your connector wires are fully inserted into their slots (sometimes they can back out through vibrations). I know that it is a PIA to go back into the dash to check, but you'll need to do it. Once you've confirmed that all of your connector wires are still fully inserted, then as suggested above, disconnect the BT adapter and see of the sound goes away. If the sound goes away, then the source of the issue is your BT adapter. If the sound remains, then the source of your issue is most likely your head unit (one or more of the electrolytic filter capacitors probably dried out and is no longer effective).
U
ukrkoz
Auburn WA
I get it. Will do and report. It's 100 outside, so in few days.
Thank you all
garyt
Are you running your bluetooth from the AUX port?
I run BT in the AUX port and started to get this about a year ago, it is the connection in the jack, if I "spin" the jack in the port it clears up and gets worse, depending on the rotation.
I had the same issue. Made the whining noise, relative to the rpm, if I had a cord plugged into the jack or not. With the cord plugged in, I could spin the cord, and get different whining noises. I had the aux jack replaced, about $75, and it cleared up the issue.
dnt1010
Tennessee
If it has rear entertainment system, then a common radio issue is the rear entertainment head unit internals have been damaged. Reach back next time it is doing it and wiggle the rear knobs to see if the pitch changes etc if so replace the rear head unit. Mine was damaged by a kids backpack strap hanging the knob when the back pack was passed from rear to front between the seats. (dang kids)
U
ukrkoz
Auburn WA
I already replaced rear stereo. This worked for maybe a month and noise came back.
algilson
This ^^^. We replaced that unit on our 2008 Sub LTZ and it instantly solved a problem that sounds the same.
U
ukrkoz
Auburn WA
As I said - I already replaced the rear stereo. It worked only temporarily and I'm not going to pay$120 every few months.
dnt1010
Tennessee
unfortunately the rear entertainment head unit is in a very exposed spot and easily damaged. Mine is still working after a couple of years mainly due to me constantly cautioning the kids to be careful around it.
Just bite the bullet and replace it again and then maybe figure out which kid (or drunk adult) is kicking the chit out of it and put a stop to that LOL
Jerryrich0806
I have a jvc tv radio in my 2011 tahoe ppv. The factory door speakers were scratching when I turn the volume all the way up. Changed them to rockafogate 6 1/2 and they scratch too with the volume all the way up. Any suggestions
Kjg238
