lowh07
Just did the all lights mod too
I do not have the rear entertainment setup. I found this video and I’m basically doing what he did minus the rear stuff. Adding in a backup camera too. I might do a thread but I suck at posting here lol
Never heard of the Crux interface. I like the Maestro but it’s probably more expensive. Post up a review of how that one works.
StrkAliteN
Is this all I need to set up my rig with trailer brakes ?
I have done a ton of real world commercial / industrial electrician work. I am guessing I can plug in and mount this mickey mouse doo dad in my '07 Yukon to prep it to haul a 20 foot enclosed cargo trailer next year.
Seems to be a popular Amazon model according to the reviews and feedback ratings ( and seems a big discount right now )
thoughts ?
I am going to replace the seal at the oil cooler take off. It's weeping a little, I tried tightening the bolts a little but to no avail. It doesn't really need replaced but I am going to do it anyway. Does anyone have an opinion over the OEM or Felpro?
If you mean the block-off, I replaced mine with the one from ICT Billet since it uses an O-ring to seal. I ran it for about 10K miles then installed a factory engine oil cooler. I gave the block-off to my neighbor and he's been running it with the gasket I had with it on mine- no problems.
ICT Billet is high quality stuff. I used their EGR block off stuff on my 02 and billet coil brackets as well. I was impressed.
Sobro
Nashville
thoughts ?
If your truck is already 7-pin trailer wired and have a "phantom" red power wire coming from the battery box you shouldn't have any problems whatsoever (he says ignoring Murphy's Law).
pwtr02ss
Tennessee
I forgot to order that when we did mine so I just used the new gm gasket and torqued to spec. The original wasn't leaking in 200k so I hope my replacement is equally as good
Mine wasn't leaking, either. But a new GM gasket was around $12. I think this was ~$17/shipped when I bought it.
I've never looked into the company, but they seem to be growing fast. Just a couple years ago, they seemed to be a small company selling a few small items on Amazon and probably ebay. Now they make all kinds of stuff and have added Summit to their list of retailers. Good for them.
The bad part about that is, I bought the gasket with plans on getting the billet piece and I just learned I didn't even need the gasket from your post. It has its own oring lol
Don't sweat it- you have and will continue to make more expensive mistakes than that. :p As car guys, we all have, do and will.
thoughts ?
Should be it. I highly recommend the Tekonsha P3, it's an excellent brake controller.
Have you watched the installation videos on eTrailer? Go on the site and enter your year, make, and model, then select the Brake Controller category. Scroll way down to the bottom where the installation videos are and have at it.
St. Louis
thoughts ?
That's a good controller. The GM adapter plug is no use for our model years though because there are just bare wires under the dash you attach the harness to.
ordered a cold-case, also thought I had addressed my little leak on the the tru cool 40k but I think I still have a loose clamp or it's leaking going to move it back up in front of the radiator once the cold case is in it should be fine up top I will find out soon enough going on a road trip in a couple weeks to points unknown....haven't decided where yet
Just Fishing
Can't fix stupid
Utah
Got to do some clean-up of the garage work space.
But the car i donated to my sister-in-laws boyfriend is broken.
It sat for a good year while he was in prison...
Battery died. So it sat for a few months more.
He just got his old job back, so they tossed in a new battery and it apparently does "nothing".
So I'm thinking they blew a fuse, or the reman starter died.
So diagnostic tools loaded, scan tool and tech2.
And bringing jackstands and a jack, and all of the tools needed to replace a starter...
I'm glad i know that car very well... lol
Fully planning to make him do the wrenching if parts need to be swapped...
Shall see how that goes...
I'm also planning to make them do an oil change.
I'm sure that will be on my dime.
What kind of vehicle is it?
RobK
