seacret radio codes
jdub5256
J-DUB
Frederica Delaware
ok everyone i joined back in oct or nov and back then i came across a thread that showed how to hit the seacret button on the nav screen and get the keypad which i know how to do. but i searched all 12 pages here and i cant find it now can anyone help me in finding these codes thanks
zach2011
Platinum Member
295660 a diagnostic menu
9448 is a more extensive version of 295660.
660 also works but you have to turn off the ignition and wait several minutes before the radio exits this menu.
stevek
Dallas, TX
Found this on another forum
The only codes I know of are
For anyone not knowing how to do this, hit the "Menu" button on the right. Hit Display on the screen. Touch the bottom left of the screen for about 5 seconds and a keypad comes up
zach2011
Platinum Member
It seems as though Toyota Tundra owners have figured out how to unlock their Nav and allow it to do other functions, because theirs has a LOADING.KWI file, which ours doesn't need. However, it could be added if I can find one to download and try out.
zach2011
Platinum Member
I found the LOADING file that the Toyota owners use to unlock their Nav, and I put it where it belongs on the DVD. I'm scared to burn it because it could severely mess up my Nav...or it could unlock it.
stevek
Dallas, TX
Warranty ;)
baron
I can't say I know who is the maker (really, the OS and build) of either the nav on the Toyota or the GM, but, simply putting some random file that works on one in the other is not generally going to do anything. Again, it depends on the nav itself, but, just an example... boot.ini is part of the boot loader for Windows and boot.efi (I believe) is the part of the loader for Max OS X. Replacing boot.ini with boot.efi (or vice versa) would likely cause the machine to not boot into either OS, but simply including one file or the other in the boot directories while leaving the original file, would likely do nothing. If you still want to try it out, like stevek said, you probably (depending on age) have a warranty, though, electronic warranties are... tricky (in my experience).
stevek
Dallas, TX
All you have to say is your battery died and then the radio didn't work after. Play dumb
eups73
What does the menu do?
zach2011
Platinum Member
Nothing interesting at all, just something to look at. 660 is annoying because you have to turn the truck off and it takes the radio forever to exit.
RobK
