Standing fully corrected on that dumbass statement. Thank you for that fact check.
The mounts on my 02’ were a SOB, but my 11’ was a breeze. Chalk it up to my angle of attack on the second go around - having the starter, exhaust manifold, tires and inner fender liners all removed?
Regardless, the toughest bolts to torque down on both vehicles were the passenger side from underneath.
I was just wondering if I had missed some critical difference...other than the actuator being in the way
Mickey_7106
Bay Area
Got some new Pirelli Scorpion AS Plus 3 (285/45R22) info here. Those suckers are rubbing my power steps when backing up at almost full turn. i need to get it aligned so im hoping that might fix it? its just barely touching.
Btw ill never buy tires at sams club. They couldn't program my new sensors and they installed those ugly ass weights to the face of one of my oem chrome esky wheels.
It’s hard to find good help nowadays.:rolleyes:
Thank you for that one. I didn’t know the 4.8 and 7.0 fell into the same category as the 5.3, and 6.2. Is that just for the Gen IV L94?
I thought there were different “setups” (AWD, 4WD) and depending on the year (aluminum block vs “cinderblock”) that made a difference in the amount of space available “under the hood”. Not specifically engine size, but the configuration of engine and drivetrain that cuts down the “wiggle room”.
Is it the 4WD vs AWD that reduced the amount of room for headers? I thought there was an issue with my 6.2, whereas the long tubes either wouldn’t fit or wouldn’t fit without coating/wrapping them, the coils, and any wiring (plus or minus the trans/oil coolant lines).
I remember reading something about it back when I was looking at headers, the setup I have either “needed” or worked best with shortys (requiring the least amount of additional mods).
Nah, the engines are all the same dimensions regardless of displacement and block material, Gen III and IV. Same with the drivetrain, barring the 6L80 vs. 4L60 differences. What does make a difference (and is the real PITA) is 4WD/AWD versus RWD. Obviously, there's much less wiggle room with a 4WD/AWD, but there's still plenty of room for headers. Yes, 4WD and AWD can be considered the same externally since the difference is the internals. The issue isn't that you have a 6.2, it's that you have AWD and some headers weren't designed to clear the front prop shaft, which is mostly a Y-pipe issue. Each header manufacturer has their own solution. Some designed their headers to fit 2WD and 4WD/AWD and may just require a drivetrain-specific Y-pipe or require modding of the standard 2WD Y-pipe when used on a 4WD/AWD. Others may have completely different headers made up to accommodate each configuration.
More specific to your application, the 6.2 only came with the 6L80 trans, which is larger than the 4L60. The 6.2 also has a larger exhaust. So, it's pretty much a double-whammy for an aftermarket header company to contend with if they were trying to make one set of headers fit all powertrain configurations.
RooTBeeRthe1st
Iirc the 5.3 and 6.2 run the same manifolds, but I don't remember about the cats and y pipe. Cat back is definitely larger. 3" instead of 2-3/4
Kee Fuller
las vegas
Got the same tires on mine. They rub when i back up and turn too. I’m lowered though and it did the same on my 24s.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
You could slide the steps back a little bit to gain clearance. Just four bolts to loosen on each side.
lowh07
And get this, BBP is refusing to delete my rear O2 sensors…
That’s crazy. They told me I’d have to sign something saying it was for off-road use only, but that never happened. I guess that was 5-6 years ago.
Headlights should be painted by now. He said they will be finished up this week, and should arrive early next
Edit: just kidding that was only about 2 years ago. Forgot that I didn’t have them tuned out for awhile. Everything’s blurring together lately
Yes, I believe the manifolds are the same and I don't know the specifics of the Y-pipe. I'm pretty sure it's a little bigger than the 4.8/5.3 pipe. It's at least gotta be a different shape to get around that 6L80. The pipe from the merge to the inlet of the muffler is 3.5" and (I think) a little smaller, like 3", from the muffler outlet to the rear exit.
lowh07
I met a local Tahoe owner who will be getting my current lights. Lives only a couple miles away and he might be joining here. He came over a few nights ago to check them out and we talked trucks for a bit. Solid dude who loves these things
soulsea
Bar
Political posts edited/deleted.
Next person that brings up politics takes a holiday.
lowh07
Lol.
alpha_omega
Michigan
Nope…no sir. I too had thought the same thing. Maybe the actuator and the starter played that much of a role in getting the ****** out of there on the passenger side. The exhaust wasn’t removed, because that’s what I used to help brace the engine when I lifted it.
I’m not sure how much more room there is between the engine/front Diff and the frame/core support on the old body style vs. the new, but there can’t be that much of a difference.
It’s not like going from the OBS blazer/jimmy/typhoons with 4.3l vortec to the NNBS. I’d say the NNBS and newer would be comparable in size to the K5 blazer more so than the S10 blazer correct?
alpha_omega
Michigan
Thank you! I knew I remember having some fitment issues but there’s too much rattling around in the ole brain box to remember it all. Time for a disc defrag and memory upgrade.
alpha_omega
Michigan
Can anyone tell me who the hell came up with the idea to put monitors on every gas pump and then thought the best option was to let them play at full volume? I was pumping gas about 2:30am and nearly started throwing rear elbows at the pump, thinking someone was trying to sneak up and play a prank on me. A guy pulled up right about that time and I could tell the look in his eyes was saying something like “uhh…this crazy MF is literally throwing blows with an imaginary person, it’s like the parking lot scene from fight club. Should I just keep driving or stop and record this?”
No joke. He pulled at the pump furthest from me. Put it in park. Left his car running and then locked the door.
Back to the original point….What’s with the screens! I know I don’t get out much, especially not without adult supervision. Are these things everywhere? They’re distracting and incredibly annoying.
Woned2004
