OBD2 splitter?
Ghost10
I have been wanting a HUD and after weeks of research it just would be easier and cheaper to use a obd2 HUD on the dash between the DIC and the left pillar instead of a OEM parts build.
Now I found this online and have some questions before I go for the build
Will this interfere with the RA003b range technologies I have plugged in?
I have heard the RT RA003 can be real Temperamental sometimes, knock on wood I have had zero issues with the device
Ryan212
The Y cable alone will not cause an issue but depending on how the 2 devices operate, they can conflict each other. The HUD could just listen to the broadcast messages to display the speed, or it could be polling the bus in a command/response method. I would ask the manufacture if the will share how that works. The range device is likely acting like a scanool to force the ecm into 8 cylinder mode.
Ghost10
Ghost10
Yeah that’s what I was afraid of I would rather have performance over aesthetics as in I really don’t need a HUD. Thanks for your reply
Sparksalot
Bastrop County, Texas
I haven’t done a splitter yet for thethirdtwin. I do use one in thecopcar for a Range device and a Scangauge. It works well.
kwhaleys
