2018 front magnetic ride
bigr528
I'm needing to replace the front magna ride on my wife's 2018 burb premier. Is it better to replace with oem or something like the Arnott sk3354, or some sort of bypass kit and quality shocks? I'm having a hard time finding the actual correct part #.
the front shock portion of the strut can be replaced (that is the part that goes bad), the spring can be compressed. so you just need the number off of the shock and punch that into rockauto
and or look up your suspension rpo code and match it up, there not expensive, see attached
B
bigr528
I'm having trouble finding the actual shocks. The part #84176638 keeps pulling up the whole assembly on my browser.
B
bigr528
Well I think I ordered the right shocks. What's the best way to replace the wires? Cut and splice or is there a way to get the wires out of the plug?
the new shocks didn't come with a plug? or a place to connect a plug? on my 2012 they just clip on the rod of the shock, if they came with just bare wires then yes you can take the old connector off with a pic tool, there is a special tool to take them apart but I have done it before by just taking it all apart carefully and using a pic tool it's not easy but can be done
B
bigr528
I'm not sure if they come with a plug. The pictures make it just look like 2 wires and no plug. I almost think cutting the wires and splicing, heat shrinking and sealing up would be the easiest. I've had terrible luck with those type of plugs on other projects lol.
so, I am guessing you haven't received them yet?
B
bigr528
Update.
New shocks came with a new plug that I had to connect to the wires on the shock. Outside of having to take the struts to a shop to compress the spring and swap out the shock, easy job. Less than an hour total on my end of the work. Went with the luftmeister on Amazon. Been riding smooth for 1,000 miles over the last 2 weeks.
Mrjvieira
