2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
That's not so much oil but grease I think. I know I over greased the crap out of them but I don't think that hurt them, maybe I'm wrong.
I have seen where oil eats rubber and even poly and I've heard you need marine synthetic grease for poly which this was just Mobile one full synthetic.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
It all depends on the compounds. Maybe they are just tore up from use.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Leverage is a wonderful thing, yeah?!
It really is! It's so dumb i remember telling myself when I first did the axleswap and saw the angles that it looked not good but, I didn't have the yoke problem until I did some other mods and then forgot about those brackets. Dumb me oh well glad it's fixed, thank you for the help :cheers:
Very possible, especially since they were at bad angles and had a lot of motion in them.
Another good news is the truck seems much more predictable now. It's hard to explain but even after the alignment it still had some odd movement. Basically when I would accelerate it would want to turn one way or the other and when I would let off the throttle it would start to point a different direction again. I can only assume it had something to do with the axle rotating so much. It seems to be completely gone now and it feels sportier than ever! I have the confidence to lay into corners with the throttle pinned now!
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Seriously in love with the improvements proper LCA angles have made. I've long been complaining that the truck is difficult to get to break the tires loose. I personally thought the 285s coupled with the G80 and very "squatty" suspension was what made it so traction happy but I think I was wrong.
There used to be this bog that happened when I would stomp it in 1st or 2nd from a slow roll. Like the suspension or drivetrain would get suddenly heavy and difficult to move. It made it so that even on the 1-2 shift it felt lazy for a split second and wouldnt even scratch the tires in the rain! For a long time I thought it was tune related or maybe some weird G80 characteristic but now that feeling is gone and its lively again!
It's been raining all day and I pulled out onto a main road in 1st gear and stomped the throttle like a roach in the kitchen. The tires broke loose immediately and so I banged into second which also broke the tires loose and began to kick the rear out! It's like I have a hot rod again and I'm really pumped because for a long time I was considering sissy skinny highway tires just so I could break traction and have some fun in this thing.
Apparently my phone did save a pic of the torn bushings. Looks like garbage and I suppose I may have over greased them a tad. View attachment 305355
Crap, I have those boxed LCA’s on mine. But last time I looked, the bushings still look new. What did you do to those? Maybe your geometry was taking it out on them?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Very possible it was a geometry problem since they likely saw considerably more movement than usual. It's just that outer lip so I'm not overly concerned more disappointed really.
id blame it on driver error
Highly likely
A lot of your power was being absorbed by the rear's rotation. You lose enough as it is transferring the power from one axis to the other in the rear end. I can't believe you still have functional U-joints on the pinion end.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well, when I first swapped in the 14b it blew the conversion joint in a week. Now it has the 1410s which are massive and before the new exhaust, the over axle pipes kept it from rotating too much.
Glad I never dynoed it with the crazy axle rotation, probably would have really broken my heart.
Lol at exhaust pipe torque arm. You Florida people sure know how to ruin vehicles.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well just got back from Vacation and in my rushed exit I left all the interior lights on and my HPT device hooked up with the LEDs on. Thankfully the battery was strong enough to still start! Unfortunately I think the AC is dead again :mad:.
It was a huge difference to feel quick throttle response and a sporty suspension compared to the expedition MAX we had all week in NC. While the 375 horses powars was pretty good for a stock truck the throttle response was lackluster at best and the drive aids drove me nuts!
Poor old girl was just left in tall grass, I didnt even put it in a barn before I left
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
This AC is driving me nuts! I was almost certain it was a tune issue again because the pressure are dead on what they should be and theres no sign of a leak anywhere. I also noticed when the AC is on the truck starts running super lean sometimes. For example, regular idle is 14.4-14.9 but it started to idle in the 17s! Then when I had it running and the AC on Looking at some other stuff I heard pressure being released suddenly so I shut the truck off and investigated. I see nowhere coolant or refrigerant were escaping but there was a noticeable cloud of what I'm nearly certain was r134 wafting away behind the truck. Still the pressures are dead on and I see nothing with the black light.
For some reason the truck just will not engage the compressor, its clearly being called on but it won't actually come on unless I manual do it with HPT special functions. It's so strange that I had these exact problems before I left for vacation but unplugging the sensors and plugging them back in worked for a week. I guess I will try that now but instead put the new AC Delco sensors in on the drier because wtf why not.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Swapped sensors but the one I bought was not the sensor on the drier its the one down low near the compressor, oh well swapped it and removed and instpected the drier sensor which looks fine. The sensor I replaced does appear original to the truck so that could be the issue. Started up and AC came right on like a good boy, Pressures are 57low and 260high but its got to be 100*+ here today and the truck has been idling heat soaking like a biotch. Guess I'll let it idle a while and then go for a drive see what it do.
Candielaine
