Oil Catch Can
eshahak
SoCal
Has anyone put one on their new Tahoe/Yukon/Suburban yet? Do they make one specifically for the new models or did you have to modify one? Is it true that GM will void a warranty if there is engine trouble after install? I would hate to install one and have the dreaded valve spring issue and lose my warranty because I installed a catch can. TIA
d0wnShifT
Charleston
Installed the JLT on my 5.3 that was a direct fit and it's caught about 5oz of oil in the past 6k miles. Already been to the dealer and they didn't say anything about it. IMO a good bit of insurance with these DI engines.
jna97
Houston Texas
What part number is it?
wsteele
You might query your dealer. I mean, I don't see a dealer calling out a benign aftermarket part on your engine if there is warranty work to be done (and get paid for). Also, I think if GM somehow found out your engine had a catch can (something I can't see happening) and refused warranty payments on a known systemic problem on your engine, I think you wouldn't have much trouble interesting an attorney to get that rectified (likely a strongly letter would do it).
When I ordered my Moroso catch can, it came with install instructions but they applied to earlier model SUV's/Trucks (which was fine with me as mine was an earlier model, 2007). There was a picture on the Amazon page where I bought it from of an install someone captured on their newer model, seemed very straight forward. They mounted it with what looked like the same fastener which holds the windshield washer tank to the body (versus to the alternator stand on mine). There are cheaper alternatives to the Moroso unit, installs would all be basically the same, I think.
I really like having it on my 2007 port injection engine (for piece of mind and a monitor for what is going on inside my motor). I can't imagine owning a direct injection engine and not having one.
E
eshahak
SoCal
Can you post a link to that item? Would love to pick that up or if there are other manufacturers that make different ones. TIA
E
eshahak
SoCal
First of all JLT has some really fast response time because I sent an email 15 minutes ago and correspondence already back and this was the response.
Thank you for the pictures. We do have a kit that will fit this application. I have supplied the link below for you to go right to the product. The suburban is now catching up to the Silverado under the hood from the earlier models.
https://www.jlttruecoldair.com/jlt-...-silverado-1500-gmc-sierra-1500-5-3l-6-2l-v8/
John Dozier
JLT Performance
1008 Executive Blvd.
Chesapeake, VA 23320
(757) 335-1940 x 100
www.JLTtruecoldair.com
www.facebook.com/JLTPerformance
Thrust
ICT
I have a UPR catch can on my F-150 Ecoboost. I would advise on paying attention to how the catch can works. Not all of them are the same and some do let oil into the intake. I've had mine for 7+ years on my truck. Only thing I've had to replace is the o-rings at the quick disconnects.
jna97
Houston Texas
John Dozier
JLT Performance
Thanks!
Fireman591
Michigan
I might add one after my factory warranty is up. Until then I would not trust GM. They will use any excuse in the book to get out of fixing something if they can blame the owner for adding an aftermarket part. Not worth the risk and as of now I am on GMs naughty list for taking their asses to court with our State's lemon law :) LOL
Dogged
Check out my post on Oct 25th on the "what did you do to your truck today" thread. It has pics of my Elite Engineering Catch can install. (I've deleted my phone pics).
I highly recommend putting one on. You will get a pool of oil quickly in yoir intake and it's imperative to keep this down on a direct injection engine since they do not clean the valves off with fuel. The lonnger you wait, the more will build up.
See if this thread link works.
https://www.tahoeyukonforum.com/threads/what-did-you-do-to-your-21-t1xx-today.116243/page-5
dukbludvl
I have a 2012 Tahoe 5.3 and a 2003 Yukon 5.3. I’d like to install catch cans on both. Any recommendations for the best product (part numbers or links are helpful too) for these applications?
Gibby13
Did you get the single or dual exit can?
RobK
