FrankU
Babylon New York
Do our radiators have the plastic end tanks that are crimped onto the ends with those aluminum tabs?
Yes they do OEM
Today did the 5th oil change since installing the 6.2
One before start up
another at 800 miles on the oil
another at 1200 miles with MM oil (trans fluid)
another at 1500 miles *** oil is still filthy***
another at 2300 miles
Oil filters done with the oil changes. I should have cracked one of the valve covers before the engine install to see what was going on under there. Was in too much of a hurry to get the engine done. Damn
St. Louis
Man, those crimped radiators have always been problematic with the seeping end tanks. I remember problems with those back in the early 90s. Some shops had a crimp tool and would just re-tighten the crimps on it.
ls1frc
Ironic... I too noticed a very very small leak that appears to be coming from the top of the driver side of the radiator end tank.
Been looking at radiators but haven't decided on which one I will go with.
It is so minor it will probably be a while.
Mine was cracked, so I went with Mishimoto. After 9 months, it's already cracked and leaking...
PG01
Up here to the right
Lol, mine is so minor, I’ve left it for 6 years.....
kbuskill
NE. FL.
You looking at factory replacements or aftermarket ones? Unless there's an upgraded one (factory or aftermarket) that's a direct replacement for my factory original and for a reasonable cost, I'm just gonna get what lasted 200K miles. I haven't even begun trying to pin down a part number yet.
We're taking the Tahoe today to dinner at my brother's house 30 minutes away since we gotta haul large Christmas gifts. I'm confident it'll be fine.
I always look for upgrades when I have to replace something.
Haven't decided on one yet.
I like this one...
https://www.radiatorexpress.com/pro.../suburban 1500/ltz/60l-v8/225639/1441063#tabs
Little pricey but probably better quality.
How much did it weigh?
No idea! The 13" trailer tires aren't even E-rated and take 35psi. Between the generator part, diesel engine and full tank of fuel, my really rough guess is 700 lbs.
It's just like this one:
ls1frc
It needs more diagnostics, but it looks cracked to me. No leaks from hoses. No coolant stains starting from any hoses.
But this area of the radiator is saturated orange and i see fluid underneath.
Smelled coolant for weeks.
the local radiator shop here, that has been here for decades... told me the aluminum radiators always leak they had never seen one that didn't and they didn't recommend any brand but they will sell one if you really want it lol.
I went thru that a couple times, had it re-crimped 2-3 months later, leaking again
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I know I will be chastised for this but that stop leak aluminum powder shit works good. I used it my whole life never had any ill effects from it for small weeps or leaks.
89Suburban
SE PA
Might be a little hard to get in there with the aluminum spool gun nozzle
Oh I figured it would have to be pulled out either way to actually find where it is leaking. I got my first MIG aluminum setup last year so I am trigger happy with it lol.
alpha_omega
Michigan
So basically any tire shop should be able to fix it pretty easily/cheaply?
Yes sir. If you live anywhere it gets cold enough that requires salt on the roads it won’t be long before your wheels end up bleeding worse or the chrome starts flaking like others have mentioned. I got tired of filling mine up whenever the temp dropped, so I ditched the 22” chromes and went aftermarket.
Woned2004
