R3cord303
Posse In Effect
Oregon Valley
Question for you all that have the 4L60e- how hard is it to install the vette servo with the trans in the vehicle? My factory reman didn’t come with one, and I didn’t get it in time to do it with the trans out of the vehicle.
I know in my S10 it wasn’t bad at all to do but i just watched a video on a GMT800 and its very tight.
wjburken
Eastern Iowa
avalonandl
Troy, MICH & Naples, FL
I had to replace a section of cast iron as well, only problem is it was buried under my concrete basement floor and ran directly under my furnace. Said screw it and ran PVC overhead to another stand pipe down stream and capped the pipe off. Dig out a 18” x 6’ section of my floor at first only to find it was bad under the furnace. Dug up a 18x18 section by the other stand pipe to cut off and cap the abandoned section. My problem was the bad section also handled my 2nd floor bathroom so I had roughly 60 gallons of literal crap I had to dig out of the trench before I filled it back in and put in new concrete.
Yukkkkkk
I didn't have much of an issue with mine, but I did it with the engine out and the trans resting on a 2x4 on the cross member. This let me shift it to the driver side a few inches for more working room. There's a convenient hump in the floor pan where you can rest the end of a pry bar against to act as a fulcrum for pushing inward on the cover. I did this to measure how much travel it had to know how much, if any, I needed to trim the longer pin (I didn't) as well as to remove tension from the retaining ring to pop it out and in.
Bigkevschopshop
Northside H-Town
Tons of driving today 250 miles to look at one. Was junked out beyond my will didn’t think it would even make it home. Found a 11 Yukon I had my eye on for a while. 84k on odometer. Decent deal. So bought it this evening then drove the 250 miles home. So here we are the silver bullet.
Here she is at her native habitat.
George ramos
