Newbie intro, 6" RC lift, 22 OEM chrome, 35" MTs
STORMIN08
my money would be on a 1.5" bolt on spacer...it is a very nice looking setup, but agreed the offset is not a GM offset ( could be factory wheel, but most likely has a spacer), could be a rep wheel.
DADW4GN
DADW4GN
Kansas City, MO
Classic "bought not built" lol. You guys are most likely correct on the spacers. I'll find out tomorrow when I start taking things apart.
olyelr
Elk Rapids, MI
Let us know. Curious if the reproduction ones have that much less backspacing, or if those are true gm wheels with spacers.
I like it though!
DADW4GN
DADW4GN
Kansas City, MO
Well, no wheel spacers, and they are an OE or at least OE replica. What I am finding is that I believe these 22" wheels are originally from the Silverado/Sierra platform, which have larger offset and backspacing. And that makes sense, because RC says cannot use stock wheels with their lift. The tricky part is what year wheels are they, since 2019+ had changes to caliper design. I've not been able to find these OE replicas with custom offset or BS.
Based on chart below, the 2019 Sierra 22s are +28mm offset with 6.10" backspacing, and Yukon/Tahoe are +24mm offset and 5.94" backspacing (though it stops at 2018 on this chart).
I'll be reaching out to the dealer I bought it from to ask for more details and will update.
olyelr
Elk Rapids, MI
Hmm. Well according to that info in the picture, the suv 22’s will actually stick out a little bit further than the truck wheels.
Most factory wheels I have seen have a manufacturer/size/offset stamped into them somewhere on the back side.
If those dont have spacers, I am guessing they are replica wheels that look just like the factory units, but have much less backspacing than the stock wheels.
DADW4GN
DADW4GN
Kansas City, MO
Alright, was able to crawl around under the truck and get some things done. Pretty much disregard my previous post.
No spacers up front, but it does have spacers in the rear. Apparently pretty common for the lifts to push the front wheels out a bit. I completely forgot to throw a tape on the rear spacers (my brain works better in reverse), but looks like 1.5-2" (I can measure if anyone wants to know exact setup).
These wheels are the 22s with +24mm offset and 5.94" backspacing.
So that's figured out and you guys were exactly right.
Trimmed up the front bumper and valence a slight bit more, and ended up just having to pound back a small section of the rear part of the front wheel wells. Pics below.
Spacers:
Trimming: 20201120_164602.jpg 20201120_164346.jpg 20201120_164355.jpg 20201120_164607.jpg
DADW4GN
DADW4GN
Kansas City, MO
Mark before I cut on driver side:
The dealer that put the lift on had trimmed just the valence a little. I carried it up the bumper a bit more at a longer angle, so the cut is not so obvious.
olyelr
Elk Rapids, MI
Thanks for the update!
Hm. So the rc lift adds to the track width up front then somehow. Let us know what size spacers are out back sometime.
Gudmat
