So, now we are talking MULTIPLE TIPS? Wow......that's really something. :boobs:
I tried to order in a pair for my 2005 and they told me some jack wagon named Wes just bought the last set. How much were they? From RA?
lol, no from amazon, the headlights were not listed as eagle eyes but I learned a long time ago if you search by the part number you can find them that way otherwise it's usually a miss on the nnbs aftermarket headlights lots of junk out there that breaks before it arrives or the adjusters are stripped, gorilla glue fixes most of that though.
$82 for the left/right set
https://www.amazon.com/gp/product/B07K2TK22R/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
the blinkers were separate about $19 each, picture shows both being the same side but the description is correct
https://www.amazon.com/gp/product/B003SZJVO0/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B003SZJV6S/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Sam Harris
From what I’ve seen the wires and plugs look pretty good. Not sure about the fuel filter, air filter is good. I changed the whole thing. MAP/MAF and throttle are all things I haven’t touched.
Being a city boy I haven’t owned a car in years so I’m getting back into cars again.
I’m kinda of the mind even if it’s been done it won’t kill it to do it again so I have my own records.
I’d be looking at some front end work as well. Likely you’ll have some parts needing some attention: ball joints, inner and outer tie rods, pitman / idler, bearings, shocks, etc..
05Single
afraid of the dark
GMT800 2005 Tahoe Z71
Navy Supporting Member
The Amazon link says fits 1999-2002 but does match for your 2005. Just goes to show what a little cross referencing will do for you.
GJones
ATL
01-02 tahoes had locks like that dave. I took my key to a local locksmith, match up the blank, cut and out in 10 minutes.
I just so happen to see on rock auto for the 02 they only sell the ones for 03+
GJones
ATL
My guy! I figured as much. I knew these would have to get done cause I’d like to slap some big wheels on her one day.
NoReverseYukon
NE Wisconsin
OK, I fired up the Tech2Win and it tells me that my speedometer doesn't require a recalibration. But when I do a sweep test it doesn't go to 50, only around 45. I'm thinking I should just reposition the needle.
What do you all think?
koomie98
