2021 Leveling/Larger tires
DWSmoot
Charleston, SC
Picking up my White Z71 this week. Looking for input on levels, max tire size, etc. Heard a rumor the wheel wells were a bit larger for bigger set up. Thinking about running a 295/60/20 if possible.
Thanks
DW
GreyStone
Thanks
DW
you looking to just raise the front or front and back?
BNK_ACCT
Right now fabtech and rough country confirmed the front leveling kit from the 15-20 will fit a 21,just a heads up.
DWSmoot
DWSmoot
Charleston, SC
[you looking to just raise the front or front and back?[/QUOTE]
Still deciding. I’m now thinking I want to run the 22” Black SGM wheel and 285/55r22 Ridge Grapplers if It will work.
similar to this
DWSmoot
DWSmoot
Charleston, SC
No. Th
You can raise it 2" inches from inside the cab already, no?
Those models are not out yet my understanding in my area anyway. I researched this and understand that the air suspensions can only me raised to 4” in 4wd. So could not run on road at 4” height all the time. That’s what I have heard anyway.
DWSmoot
DWSmoot
Charleston, SC
That wheel/tire combo looks good
I think so. Looks like I will need to drop the tires size to 285/50r22. The test fit today of the 285/55 were rubbing in the rear of the front fender well. Tonight I pulled the liner back and looks like there is a frame member right where it is rubbing so no trimming. This is different than my 2017.
GreyStone
would you say the K2XXs have more room in the wheel well?
DWSmoot
DWSmoot
Charleston, SC
Looks great, I would caution against changing the tires and wheels right away until it is known how the new size will or will not work with the computer systems. They're very different from the previous generations.
Thanks for the heads up. Having it done at the dealership. The Z71 comes stock with 275/60/20 which is a 33” tire. I am only increasing .6 inches. Hopefully there won’t be an issue.
Woned2004
